跳转到主内容
加入维修社区 - 创建账户
Connect Four Electronic Handheld Screen Replacement
你所需要的
    1. Connect Four Electronic Handheld Screen Replacement, Ensure the device is off.: 步骤 1 中的图像 1,1
      • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
      询问修复机器人
      添加评论
    2. Connect Four Electronic Handheld Screen Replacement, Removing the battery casing.: 步骤 2 中的图像 1,2 Connect Four Electronic Handheld Screen Replacement, Removing the battery casing.: 步骤 2 中的图像 2,2
      • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
      • Slide the cover off and remove the battery.
      询问修复机器人
      添加评论
    1. Connect Four Electronic Handheld Screen Replacement, Removing/Replacing the Back Casing: 步骤 3 中的图像 1,2 Connect Four Electronic Handheld Screen Replacement, Removing/Replacing the Back Casing: 步骤 3 中的图像 2,2
      • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
      • Carefully remove the back casing.
      • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
      询问修复机器人
      添加评论
    1. Connect Four Electronic Handheld Screen Replacement, Detaching the circuit board.: 步骤 4 中的图像 1,3 Connect Four Electronic Handheld Screen Replacement, Detaching the circuit board.: 步骤 4 中的图像 2,3 Connect Four Electronic Handheld Screen Replacement, Detaching the circuit board.: 步骤 4 中的图像 3,3
      • Using a Phillips head screwdriver, remove the six (0.25"-length) #3 screws that hold down the cpu board.
      • Using a plastic opening tool, lever the circuit board just enough to where you can easily access the button sheet.
      询问修复机器人
      添加评论
    2. Connect Four Electronic Handheld Screen Replacement, Removing the Circuit Board: 步骤 5 中的图像 1,2 Connect Four Electronic Handheld Screen Replacement, Removing the Circuit Board: 步骤 5 中的图像 2,2
      在这个步骤中使用的工具:
      • Pop out the wires, connected to the battery terminals, out of their place. You can use a plastic opening tool or fine tweezers for this step.
      • The wires in this image have already been detached.
      • Check that there is no power going into the device that could pose any shock hazard.
      • Once the terminals are out of place, remove the circuit board.
      询问修复机器人
      添加评论
    3. Connect Four Electronic Handheld Screen Replacement, Replacing the Screen: 步骤 6 中的图像 1,1
      • Take the old screen out.
      • Replace the old screen with the new screen.
      • Ensure that the screen is facing right side up, where there is more yellow space under the checkered board.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Wil
于10/22/14注册
313 声望
创作了3篇指南
团队
Baylor, Team 8-11, Williams Fall 2014 Baylor, Team 8-11, Williams Fall 2014 的会员
BU-WILLIAMS-F14S8G11
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 20
总计 798
