跳转到主内容
加入维修社区 - 创建账户
Compaq Mini 110 Keyboard Replacement
你所需要的
  1. Compaq Mini 110 Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Compaq Mini 110 Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
    询问修复机器人
    添加评论
  2. Compaq Mini 110 Keyboard Replacement: 步骤 2 中的图像 1,3 Compaq Mini 110 Keyboard Replacement: 步骤 2 中的图像 2,3 Compaq Mini 110 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Push both tabs inward simultaneously and slide the battery out.
    询问修复机器人
    添加评论
  3. Compaq Mini 110 Keyboard Replacement, RAM: 步骤 3 中的图像 1,2 Compaq Mini 110 Keyboard Replacement, RAM: 步骤 3 中的图像 2,2
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
    添加评论
  4. Compaq Mini 110 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
    询问修复机器人
    添加评论
  5. Compaq Mini 110 Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,2 Compaq Mini 110 Keyboard Replacement, Keyboard: 步骤 5 中的图像 2,2
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
    询问修复机器人
    添加评论
  6. Compaq Mini 110 Keyboard Replacement: 步骤 6 中的图像 1,2 Compaq Mini 110 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
    询问修复机器人
    添加评论
  7. Compaq Mini 110 Keyboard Replacement: 步骤 7 中的图像 1,2 Compaq Mini 110 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Unscrew the screw for the bottom case located in the RAM compartment.
    添加评论
  8. Compaq Mini 110 Keyboard Replacement: 步骤 8 中的图像 1,2 Compaq Mini 110 Keyboard Replacement: 步骤 8 中的图像 2,2
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
alea
于10/06/10注册
1,429 声望
创作了14篇指南
团队
Cal Poly, Team 22-2, Maness Fall 2010 Cal Poly, Team 22-2, Maness Fall 2010 的会员
CPSU-MANESS-F10S22G2
6 名成员
创作了20篇指南
3指南评论
hi, steps 5 and 6 are not needed. not sure about removing RAM either. If I look on my removed keyboard, all I see are three places for screws - those located nearby battery socket.
Petr Gebelt - 回复 分享
I think steps 3,4,5,6,7 are not needed! The essential problem in removing the keyboard is not shown: how to lift the keyboard! Use the flat side or back of a screwdriver to push the metal strips shown in step 8 up (in the direction of the keyboard) to lift the keyboard. Put your fingers under the edge of the keyboard and pull gently but firmly. There is some resistance of the holding cover.
See also: https://www.youtube.com/watch?v=nELBz1VB...
Hans Donck - 回复 分享
Thank you so much for the link!
Alex - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 40
总计 17,380
