跳转到主内容
加入维修社区 - 创建账户
Compaq Mini 110 Display Assembly Replacement
你所需要的
  1. Compaq Mini 110 Display Assembly Replacement, Battery: 步骤 1 中的图像 1,2 Compaq Mini 110 Display Assembly Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
    询问修复机器人
    添加评论
  2. Compaq Mini 110 Display Assembly Replacement: 步骤 2 中的图像 1,3 Compaq Mini 110 Display Assembly Replacement: 步骤 2 中的图像 2,3 Compaq Mini 110 Display Assembly Replacement: 步骤 2 中的图像 3,3
    • Push both tabs inward simultaneously and slide the battery out.
    询问修复机器人
    添加评论
  3. Compaq Mini 110 Display Assembly Replacement, RAM: 步骤 3 中的图像 1,2 Compaq Mini 110 Display Assembly Replacement, RAM: 步骤 3 中的图像 2,2
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
    添加评论
  4. Compaq Mini 110 Display Assembly Replacement: 步骤 4 中的图像 1,1
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
    询问修复机器人
    添加评论
  5. Compaq Mini 110 Display Assembly Replacement, Keyboard: 步骤 5 中的图像 1,2 Compaq Mini 110 Display Assembly Replacement, Keyboard: 步骤 5 中的图像 2,2
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
    询问修复机器人
    添加评论
  6. Compaq Mini 110 Display Assembly Replacement: 步骤 6 中的图像 1,2 Compaq Mini 110 Display Assembly Replacement: 步骤 6 中的图像 2,2
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
    询问修复机器人
    添加评论
  7. Compaq Mini 110 Display Assembly Replacement: 步骤 7 中的图像 1,2 Compaq Mini 110 Display Assembly Replacement: 步骤 7 中的图像 2,2
    • Unscrew the screw for the bottom case located in the RAM compartment.
    添加评论
  8. Compaq Mini 110 Display Assembly Replacement: 步骤 8 中的图像 1,2 Compaq Mini 110 Display Assembly Replacement: 步骤 8 中的图像 2,2
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
    添加评论
  9. Compaq Mini 110 Display Assembly Replacement, Hard Drive: 步骤 9 中的图像 1,1
    • Remove the three screws holding the panel in place.
    询问修复机器人
    添加评论
  10. Compaq Mini 110 Display Assembly Replacement: 步骤 10 中的图像 1,2 Compaq Mini 110 Display Assembly Replacement: 步骤 10 中的图像 2,2
    • Pull up on the tab to remove the hard drive.
    询问修复机器人
    添加评论
  11. Compaq Mini 110 Display Assembly Replacement, Top Cover: 步骤 11 中的图像 1,1
    • Remove the eight screws that are from the plastic top cover.
    询问修复机器人
    添加评论
  12. Compaq Mini 110 Display Assembly Replacement: 步骤 12 中的图像 1,3 Compaq Mini 110 Display Assembly Replacement: 步骤 12 中的图像 2,3 Compaq Mini 110 Display Assembly Replacement: 步骤 12 中的图像 3,3
    • Pry up the top plastic cover using a spudger.
    • These two tabs under the screen need to be pushed in with a spudger.
    询问修复机器人
    添加评论
  13. Compaq Mini 110 Display Assembly Replacement: 步骤 13 中的图像 1,2 Compaq Mini 110 Display Assembly Replacement: 步骤 13 中的图像 2,2
    • Remove the cable by carefully pulling it up.
    • Be careful when lifting up the cover because the track pad is still attached.
    询问修复机器人
    添加评论
  14. Compaq Mini 110 Display Assembly Replacement, Display Assembly: 步骤 14 中的图像 1,3 Compaq Mini 110 Display Assembly Replacement, Display Assembly: 步骤 14 中的图像 2,3 Compaq Mini 110 Display Assembly Replacement, Display Assembly: 步骤 14 中的图像 3,3
    • Remove the four screws that keep the bottom of the hinges attached to the base.
    询问修复机器人
    添加评论
  15. Compaq Mini 110 Display Assembly Replacement: 步骤 15 中的图像 1,3 Compaq Mini 110 Display Assembly Replacement: 步骤 15 中的图像 2,3 Compaq Mini 110 Display Assembly Replacement: 步骤 15 中的图像 3,3
    • Pry off the top plastic cover of the display assembly.
    • The spudger may go all the way through to the screen-side of the cover. This is not a problem and won't damage anything.
    • There is adhesive tape holding the cover on.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
alea
于10/06/10注册
1,429 声望
创作了14篇指南
团队
Cal Poly, Team 22-2, Maness Fall 2010 Cal Poly, Team 22-2, Maness Fall 2010 的会员
CPSU-MANESS-F10S22G2
6 名成员
创作了20篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 37
总计 7,750
