跳转到主内容
加入维修社区 - 创建账户
ClickN Kids Tablet Touch Screen Display Replacement
你所需要的
  1. ClickN Kids Tablet Touch Screen Display Replacement, Touch Screen Display: 步骤 1 中的图像 1,1
    • Start on the side with the camera. The screen side is black, the back side is colored
    • Insert a plastic opening tool into the space between the screen and the back side.
    询问修复机器人
    添加评论
  2. ClickN Kids Tablet Touch Screen Display Replacement: 步骤 2 中的图像 1,1
    • Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
    • Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
    询问修复机器人
    添加评论
  3. ClickN Kids Tablet Touch Screen Display Replacement: 步骤 3 中的图像 1,1
    • Lift the detached screen from the camera side until you can see the inside of the tablet.
    • Potential for device damage. Don't open too fast, or you might damage the ribbon cables.
    询问修复机器人
    添加评论
  4. ClickN Kids Tablet Touch Screen Display Replacement: 步骤 4 中的图像 1,2 ClickN Kids Tablet Touch Screen Display Replacement: 步骤 4 中的图像 2,2
    • Potential for device damage. Be careful not to damage any wires or ribbon cables during this step.
    • There are two ribbon cables to remove during this step. Each is connected to a base on the motherboard.
    • There is a black tab behind the long ribbon cable. Lift up the black tab.
    • For the ribbon cable in the back, pull the black tabs on the side out.
    • Detach the ribbon cables connecting the screen to the motherboard.
    • Remove any tape that is holding down the ribbon cables. Set it aside.
    • Once the ribbon cables are freed, separate the top and bottom sides.
    询问修复机器人
    添加评论
  5. ClickN Kids Tablet Touch Screen Display Replacement: 步骤 5 中的图像 1,2 ClickN Kids Tablet Touch Screen Display Replacement: 步骤 5 中的图像 2,2
    • Remove the yellow tape on the right side. Easiest side to get.
    • Remove the black and yellow tape stuck together on the left and bottom sides of the screen.
    询问修复机器人
    添加评论
  6. ClickN Kids Tablet Touch Screen Display Replacement: 步骤 6 中的图像 1,1
    • Potential for device damage. Make sure the screen is facedown and level to prevent or reduce damage to the display.
    • Potential for device damage. There is an adhesive on the top edge of the display’s face. Be careful not to damage the display.
    • Flex the sides of the tablet until the clips holding the display to the screen case pop loose.
    询问修复机器人
    添加评论
  7. ClickN Kids Tablet Touch Screen Display Replacement: 步骤 7 中的图像 1,2 ClickN Kids Tablet Touch Screen Display Replacement: 步骤 7 中的图像 2,2
    • Be careful not to damage the display or screen case.
    • Pull the display from the top side to detach it from the screen case.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
Kevin Finney
于03/22/15注册
562 声望
创作了4篇指南
团队
Baylor, Team 4-4, Williams Spring 2015 Baylor, Team 4-4, Williams Spring 2015 的会员
BU-WILLIAMS-S15S4G4
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 34
总计 8,372
