简介
Follow this guide to remove and replace the cutting blade for the Classen Sod Cutter SC18AHDCA.
你所需要的
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 1/2" socket wrench to remove the six 1 inch-long bolts securing both ends of the blade. You may need to use a 1/2" combination wrench to hold the nuts in place.
Grasp the back of the blade and slide it away from the mount.
Remove the blade.
2等其他人完成本指南。
