跳转到主内容
Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement
你所需要的
  1. Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement, Dust Bag: 步骤 1 中的图像 1,2 Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement, Dust Bag: 步骤 1 中的图像 2,2
    • Before you begin, be sure that the sander is unplugged and powered off.
    • Twist and pull the dust bag collar to disconnect it from the elbow pipe.
    • Remove the dust bag.
  2. Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement, Grip Face Pad: 步骤 2 中的图像 1,2 Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement, Grip Face Pad: 步骤 2 中的图像 2,2
    • Lock the handle in place by pulling the lock lever upwards.
    • Test the lock by wobbling the handle and making sure that it is not loose.
  3. Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 3 中的图像 1,3 Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 3 中的图像 2,3 Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 3 中的图像 3,3
    • This step shows how to lay the sander on its back.
    • Brace the wheel axle with your foot and grasp the handle with both hands.
    • Slowly tilt the handle downwards until it rests on your work surface.
  4. Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 4 中的图像 1,1
    • Untie and loosen the drawstring securing the dust skirt.
  5. Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 5 中的图像 1,2 Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 5 中的图像 2,2
    • Slide the dust skirt off of the bottom plate and remove it.
  6. Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 6 中的图像 1,3 Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 6 中的图像 2,3 Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 6 中的图像 3,3
    • Peel the red pad away from the grip face and remove it.
  7. Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 7 中的图像 1,3 Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 7 中的图像 2,3 Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 7 中的图像 3,3
    • The grip face pad is attached to the base plate by a layer of spongy adhesive.
    • Press the edge of a putty knife or flat scraper into the adhesive layer sandwiched between the grip face pad and base plate.
    • Push and wiggle the putty knife to slice into the adhesive.
  8. Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 8 中的图像 1,3 Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 8 中的图像 2,3 Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 8 中的图像 3,3
    • Slide the putty knife along the edge to slice through the adhesive.
    • Apply force to the handle and wiggle the putty knife to help with the slicing.
    • Continue slicing into the adhesive.
  9. Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 9 中的图像 1,2 Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 9 中的图像 2,2
    • Once you have a sizable area detached, pull on the grip face pad while you slice to help with the process.
    • Continue slicing until you have detached the grip face pad.
    • Remove the grip face pad.
  10. Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 10 中的图像 1,3 Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 10 中的图像 2,3 Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 10 中的图像 3,3
    • In order for the new grip face pad to adhere properly, you must remove all uneven adhesive residue from the base plate.
    • Use a powered wire wheel brush, putty knife, or scraper to remove large chunks of adhesive.
    • Alternatively, spray the entire surface with Xylene or other solvent that dissolves adhesive, let it soak for ten to fifteen minutes and the adhesive will peel off with minimal effort.
    • Remove any remaining residue with a fine wire wheel brush or coarse (50~100) grit sander. The final surface should feel smooth.
    • For your safety, wear a dust mask and safety glasses while sanding.
    • Clean the surface with some isopropyl alcohol.
  11. Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 11 中的图像 1,1
    • Peel the replacement grip face pad's adhesive liner one inch from a short edge.
  12. Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 12 中的图像 1,3 Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 12 中的图像 2,3 Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 12 中的图像 3,3
    • The adhesive is extremely tacky! You only have one chance to align the grip face pad properly to the base.
    • Carefully line up the grip face pad to the base, ensuring that all the edges line up.
    • Press the right edge of the pad (with exposed adhesive) onto the base.
    • Pull the adhesive liner from behind the pad and remove it to expose the remaining adhesive.
    • Look at the liner you just pulled out and make sure it hasn't ripped and left some of the liner on the back of the pad.
  13. Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 13 中的图像 1,3 Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 13 中的图像 2,3 Clarke Floor Sander 07014A 2012 Grip Face Pad Replacement: 步骤 13 中的图像 3,3
    • Press the grip face pad onto the base plate.
    • You don't have press very hard. Just ensure that the pad is properly in position.
    • Press the red pad back onto the grip face pad.
    • Carefully swing the sander back upright so that its weight presses against the base plate.
    • Allow the sander to sit in this position for an hour to help the grip face pad's adhesive to bond.
终点
17等其他人完成本指南。
Arthur Shi
于01/03/18注册
254,567 声望
创作了529篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
一条评论
A multi tool of any brand works great for removing pad and adhesive.
STEVEN - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 23
过去 30 天: 72
总计 4,153
