跳转到主内容
加入维修社区 - 创建账户
Cirago M9030 IDE Connector Replacement
你所需要的
  1. Cirago M9030 IDE Connector Replacement, Cover: 步骤 1 中的图像 1,1
    • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
    询问修复机器人
    添加评论
  2. Cirago M9030 IDE Connector Replacement: 步骤 2 中的图像 1,1
    • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
    • Remove the warranty sticker across the bottom.
    询问修复机器人
    添加评论
  3. Cirago M9030 IDE Connector Replacement: 步骤 3 中的图像 1,2 Cirago M9030 IDE Connector Replacement: 步骤 3 中的图像 2,2
    • Gently take the cover apart using your hands separating the top and bottom.
    • The outer shell is expected to easily come apart.
    询问修复机器人
    添加评论
  4. Cirago M9030 IDE Connector Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Make sure that the screen of the device is facing down.
    询问修复机器人
    添加评论
  5. Cirago M9030 IDE Connector Replacement: 步骤 5 中的图像 1,3 Cirago M9030 IDE Connector Replacement: 步骤 5 中的图像 2,3 Cirago M9030 IDE Connector Replacement: 步骤 5 中的图像 3,3
    • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
    • Raise the bottom edge of the hard drive 15 degrees up from the device.
    询问修复机器人
    添加评论
  6. Cirago M9030 IDE Connector Replacement: 步骤 6 中的图像 1,3 Cirago M9030 IDE Connector Replacement: 步骤 6 中的图像 2,3 Cirago M9030 IDE Connector Replacement: 步骤 6 中的图像 3,3
    • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
    询问修复机器人
    添加评论
  7. Cirago M9030 IDE Connector Replacement, IDE Connector: 步骤 7 中的图像 1,2 Cirago M9030 IDE Connector Replacement, IDE Connector: 步骤 7 中的图像 2,2
    • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
    询问修复机器人
    添加评论
  8. Cirago M9030 IDE Connector Replacement: 步骤 8 中的图像 1,1
    • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
    询问修复机器人
    添加评论
  9. Cirago M9030 IDE Connector Replacement: 步骤 9 中的图像 1,2 Cirago M9030 IDE Connector Replacement: 步骤 9 中的图像 2,2
    • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
    • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
    询问修复机器人
    添加评论
  10. Cirago M9030 IDE Connector Replacement: 步骤 10 中的图像 1,1
    • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
    询问修复机器人
    添加评论
  11. Cirago M9030 IDE Connector Replacement: 步骤 11 中的图像 1,2 Cirago M9030 IDE Connector Replacement: 步骤 11 中的图像 2,2
    • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
    • Completely remove the IDE connector from the device.
    询问修复机器人
    添加评论
结论
To reassemble your device, follow these instructions in reverse order. Once you've replaced the IDE connector and reassembled your Cirago M9030, your device should be able to detect hard drives properly again. If everything is connected correctly, your repair is complete. Great job!
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team 1-4, Regan SU 2012 Cal Poly, Team 1-4, Regan SU 2012 的会员
CPSU-REGAN-SU12S1G4
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 9
过去 30 天: 31
总计 1,301
