跳转到主内容
加入维修社区 - 创建账户
Chef's Choice M115 Power Switch Replacement
你所需要的
    1. Chef's Choice M115 Power Switch Replacement, Case: 步骤 1 中的图像 1,2 Chef's Choice M115 Power Switch Replacement, Case: 步骤 1 中的图像 2,2
      • Remove the two rubber feet on the motor side of the device.
      • Remove the five Phillips screws from the bottom of the case.
      • These screws are recessed deep in the device, so a long, thin screwdriver is required.
      询问修复机器人
      添加评论
    2. Chef's Choice M115 Power Switch Replacement: 步骤 2 中的图像 1,1
      • Remove the two hex-cap screws on the bottom using a pair of pliers.
      询问修复机器人
      添加评论
    3. Chef's Choice M115 Power Switch Replacement: 步骤 3 中的图像 1,1
      • Carefully flip the device right-side-up while grasping the top and bottom pieces.
      • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
      询问修复机器人
      添加评论
    4. Chef's Choice M115 Power Switch Replacement: 步骤 4 中的图像 1,1
      • Remove the sharpener guard by gently pulling up on it.
      • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
      询问修复机器人
      添加评论
    1. Chef's Choice M115 Power Switch Replacement, Power Switch: 步骤 5 中的图像 1,1
      • Carefully lift the entire motor assembly out of the case.
      询问修复机器人
      添加评论
    2. Chef's Choice M115 Power Switch Replacement: 步骤 6 中的图像 1,2 Chef's Choice M115 Power Switch Replacement: 步骤 6 中的图像 2,2
      • Using a screw driver, unclip the edges of the switch by pushing them inwards and nudging the switch out of the plastic casing. You will hear a click when the edges unhook from the casing.
      询问修复机器人
      添加评论
    3. Chef's Choice M115 Power Switch Replacement: 步骤 7 中的图像 1,2 Chef's Choice M115 Power Switch Replacement: 步骤 7 中的图像 2,2
      • Remove the spade connectors from the switch by pulling only on the connector, not the wire.
      • This may require a fair bit of force. Use caution to not damage the device, yourself, or your surroundings.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
IUPUI, Team 3-3, Harley Fall 2015 IUPUI, Team 3-3, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S3G3
5 名成员
创作了43篇指南
1指南评论
What kind of switch should I replace the bad switch with? Is there one on Amazon ?
Ryan Frawley - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 31
总计 703
