跳转到主内容
加入维修社区 - 创建账户
Cen-Tech Seven Function Digital Multimeter Battery Replacement
你所需要的
    1. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Position Device: 步骤 1 中的图像 1,1
      • Place the meter face down, and the back panel and screws can be seen.
      询问修复机器人
      添加评论
    2. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Back Panel Screws: 步骤 2 中的图像 1,2 Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Back Panel Screws: 步骤 2 中的图像 2,2
      • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
      询问修复机器人
      添加评论
    3. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Back Panel: 步骤 3 中的图像 1,1
      • Remove the back panel of the device by lifting upward.
      • Remove the battery from the meter before continuing.
      询问修复机器人
      添加评论
    4. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Unscrew Motherboard: 步骤 4 中的图像 1,2 Cen-Tech Seven Function Digital Multimeter Battery Replacement, Unscrew Motherboard: 步骤 4 中的图像 2,2
      • Remove the four 7mm Phillips screws holding the circuit board in place.
      询问修复机器人
      添加评论
    5. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Motherboard: 步骤 5 中的图像 1,1
      • Gently lift the circuit board away from the device casing.
      • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
      询问修复机器人
      添加评论
    1. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Locate Battery Attachment: 步骤 6 中的图像 1,1
      • After removing the outer casing and motherboard of the device, locate the attachment site of the battery to the motherboard.
      询问修复机器人
      添加评论
    2. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Battery: 步骤 7 中的图像 1,1
      • Unsnap the battery from its attachment plate.
      • When replacing the battery with a new one, be sure to properly align battery heads (positive and negative) with snaps. The positive battery head should be connected to the negative wire, and vice versa.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
Anna Kihm
于10/13/14注册
965 声望
创作了5篇指南
团队
Clemson, Team 2-4, Benson Fall 2014 Clemson, Team 2-4, Benson Fall 2014 的会员
CLEM-BENSON-F14S2G4
4 名成员
创作了18篇指南
6指南评论
My case was glued or welded together. I thought it was going to break elsewhere first
No need to remove the board. Just use a screwdriver to pop the battery connector off
Osman Vincent - 回复 分享
In at least some of these meters, the caution label has been applied upside-down, so that it covers the screw holes.
dan - 回复 分享
The top of the panel has two tabs engaged (can be seen by carefully examining photos above). After screws are freed, lift the bottom edge first to allow tabs to disengage. Also, routing of battery clip wires is critical; take care that they clear the case edges.
dan - 回复 分享
Can't get 2nd screw out!!
KARIN SPURLING - 回复 分享
I had a spring in mine, and when my grandson took it apart to change battery, I don’t know where the spring came out
Rodney Grainger - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 18
过去 30 天: 100
总计 16,400
