简介
If the dial cannot spin then it is likely that the ball bearings are missing or not properly lubricated.
你所需要的
Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
Remove the back panel of the device by lifting upward.
Remove the battery from the meter before continuing.
Carefully remove dial from device by lifting upward.
Clean existing dial or replace if necessary.
Locate ball bearings. Carefully remove.
If both ball bearings are still present, try lubricating ball bearings with multi-use lubricant.
If one or both ball bearings are missing, simply replace.
4等其他人完成本指南。
