跳转到主内容
加入维修社区 - 创建账户
Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch Replacement
你所需要的
    1. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Position Device: 步骤 1 中的图像 1,1
      • Place the meter face down, and the back panel and screws can be seen.
      询问修复机器人
      添加评论
    2. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Remove Back Panel Screws: 步骤 2 中的图像 1,2 Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Remove Back Panel Screws: 步骤 2 中的图像 2,2
      • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
      询问修复机器人
      添加评论
    3. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Remove Back Panel: 步骤 3 中的图像 1,1
      • Remove the back panel of the device by lifting upward.
      • Remove the battery from the meter before continuing.
      询问修复机器人
      添加评论
    4. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Unscrew Motherboard: 步骤 4 中的图像 1,2 Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Unscrew Motherboard: 步骤 4 中的图像 2,2
      • Remove the four 7mm Phillips screws holding the circuit board in place.
      询问修复机器人
      添加评论
    5. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Remove Motherboard: 步骤 5 中的图像 1,1
      • Gently lift the circuit board away from the device casing.
      • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
      询问修复机器人
      添加评论
    1. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Locate 'On'/'Off' Switch: 步骤 6 中的图像 1,1
      • The 'on'/'off' switch is located directly beneath the dial.
      询问修复机器人
      添加评论
    2. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Remove 'On'/'Off' Switch: 步骤 7 中的图像 1,1
      • Gently remove switch from device by lifting upward.
      • Either clean or replace switch.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
团队
Clemson, Team 2-4, Benson Fall 2014 Clemson, Team 2-4, Benson Fall 2014 的会员
CLEM-BENSON-F14S2G4
4 名成员
创作了24篇指南
1指南评论
Hi Great site love it, Where can you purchase the copper contacts and is there a technical name for them didn’t know that I could have repaired much craftsman 82040 meter by piecing out the harbor freight free meterand using the contacts which were worn out and non repairable and started to hand make them and then ran across this site. Thanks for the tutorial and being part of the solution as i am an automotive parts rebuilder keeping land fills few of good core since 1988.
Joel - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 30
总计 2,233
