此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
如果你的 Caterpillar 手机突然关机,可能是电池故障引起的。为了保护手机免受电涌影响,它在遇到电池故障时会自动彻底关机。连接充电器时可能会亮起红色 LED 指示灯,但在更换电池之前手机将无法开机。本指南将引导你完成电池更换过程,以确保操作安全且规范。
你所需要的
Caterpillar CAT S41 机身内置了 3 个抗水密封盖板,分别位于耳机孔、充电口以及 SIM 卡和 TF/SD 卡组合插槽上方。
松开这 3 个接口盖板。
要重新组装设备,请按相反顺序执行这些说明。
5等其他人完成本指南。
2指南评论
Have a nice day. I own a cat s41 phone. How can I get the original front and back case?
Atakan Yüklü - 回复 分享
Unfortunately I do not know where to buy this part you need. After a search there does not seem to be any reputable vendors selling such.
The best thing I can suggest is buying a broken phone listed as "for parts" or "as/is" or "not working" or etc. If you can inspect the photos to see if the parts you need are in good condition that would work to disassemble and harvest the parts you need. I can see some listed on ebay between $25-$50 USD + shipping, but you may have better luck elsewhere or at marketplaces more local to you.
