跳转到主内容
加入维修社区 - 创建账户
Caterpillar B15 LCD Replacement
你所需要的
    1. Caterpillar B15 LCD Replacement, Caterpillar B15 Teardown: 步骤 1 中的图像 1,1
      • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
      询问修复机器人
      添加评论
    2. Caterpillar B15 LCD Replacement: 步骤 2 中的图像 1,2 Caterpillar B15 LCD Replacement: 步骤 2 中的图像 2,2
      • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
      询问修复机器人
      添加评论
    3. Caterpillar B15 LCD Replacement: 步骤 3 中的图像 1,2 Caterpillar B15 LCD Replacement: 步骤 3 中的图像 2,2
      • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone.
      询问修复机器人
      添加评论
    4. Caterpillar B15 LCD Replacement: 步骤 4 中的图像 1,2 Caterpillar B15 LCD Replacement: 步骤 4 中的图像 2,2
      • With the back cover removed, locate and remove the Phillips screw pictured top-center, and the two torx screws above and to either side of the Phillips screw. A T-5 bit is required for removal of the torx screws.
      • WARNING: Proceeding beyond this point will void the warranty for this device.
      询问修复机器人
      添加评论
    5. Caterpillar B15 LCD Replacement: 步骤 5 中的图像 1,1
      • Next, remove the two torx (star-shaped) screws below the battery. These screws help to secure the outer shell of the phone around the motherboard. A T-5 bit is required for removal.
      询问修复机器人
      添加评论
    6. Caterpillar B15 LCD Replacement: 步骤 6 中的图像 1,1
      • There are three remaining screws on each long side of the phone. A small hex bit is required for removal.
      询问修复机器人
      添加评论
    7. Caterpillar B15 LCD Replacement: 步骤 7 中的图像 1,1
      • There is one more Phillips screw remaining. It is located beneath the headphone cover.
      询问修复机器人
      添加评论
    8. Caterpillar B15 LCD Replacement: 步骤 8 中的图像 1,1
      • With all screws removed, the back and side pieces should come off the front of the phone, exposing the motherboard and various components as shown.
      询问修复机器人
      添加评论
    9. Caterpillar B15 LCD Replacement: 步骤 9 中的图像 1,1
      • With all screws removed, move around the motherboard, carefully prying it from the remaining shell.
      询问修复机器人
      添加评论
    10. Caterpillar B15 LCD Replacement: 步骤 10 中的图像 1,1
      • Finally, disconnect the chip seen in the upper right, and the board should pull away from the rest of the phone.
      询问修复机器人
      添加评论
    11. Caterpillar B15 LCD Replacement: 步骤 11 中的图像 1,1
      • Congratulations. You have successfully disassembled the Caterpillar B15.
      询问修复机器人
      添加评论
    1. Caterpillar B15 LCD Replacement, LCD: 步骤 12 中的图像 1,1
      • With the device completely disassembled, the LCD can easily be accessed. It is pictured here, in which it adheres to the front of the motherboard.
      询问修复机器人
      添加评论
    2. Caterpillar B15 LCD Replacement: 步骤 13 中的图像 1,1
      • The LCD is held to the board by an adhesive, and will peel away with either a spudger or by hand. Disconnect any ribbon cables if applicable.
      询问修复机器人
      添加评论
    3. Caterpillar B15 LCD Replacement: 步骤 14 中的图像 1,1
      • Installing the new LCD is the reverse of removing the old one. The 2mm 3M adhesive tape listed in the guide is recommended for fixing the new display to the board.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
9等其他人完成本指南。
团队
USF Tampa, Team 4-7, Brown Fall 2014 USF Tampa, Team 4-7, Brown Fall 2014 的会员
USFT-BROWN-F14S4G7
4 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 28
总计 7,568
