跳转到主内容
加入维修社区 - 创建账户
Casio LK-170 Key Replacement
你所需要的
    1. Casio LK-170 Key Replacement, Key: 步骤 1 中的图像 1,3 Casio LK-170 Key Replacement, Key: 步骤 1 中的图像 2,3 Casio LK-170 Key Replacement, Key: 步骤 1 中的图像 3,3
      • You will be removing 17 11mm screws with a JIS-1 screwdriver to detach the back of the keyboard from the front.
      • You will begin by removing 4 screws on each side of the piano, circled in red.
      • You will then remove the four screws that are a little hidden, circled in orange.
      • Next, remove the two screws in the middle of piano, as well as the three screws on the top of the piano, circled in yellow.
      添加评论
    2. Casio LK-170 Key Replacement: 步骤 2 中的图像 1,2 Casio LK-170 Key Replacement: 步骤 2 中的图像 2,2
      • After flipping the keyboard over to the front, carefully remove the the front panel from the back panel of the keyboard using your hands.
      • You should now see the screws holding the keys in place.
      • There are five 18mm screws per section of keys.
      • With a JIS-1 bit, unscrew the five screws in the section with the key you want to replace.
      询问修复机器人
      添加评论
    3. Casio LK-170 Key Replacement: 步骤 3 中的图像 1,2 Casio LK-170 Key Replacement: 步骤 3 中的图像 2,2
      • You will be able to pick up the white keys with your hands and remove them.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 13-2, Banghart Winter 2017 Cal Poly, Team 13-2, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S13G2
3 名成员
创作了5篇指南
2指南评论
This guide also works for the Casio LK-175.
The keys are in small groups and you will need to purchase the correct ones. Unfortunately, the ones I received from a seller did not match. I think he thought the part was compatible between my keyboard and the one he pulled them from. I very carefully tried super-gluing the key back onto it's section and so far so good (a few hours). Hopefully, the repair will hold.
Thank you for the guide Samantha.
Steve Ferrel - 回复 分享
Do you know if this exposes the circuit board(s)? I need to open my Casio LK175 to figure out why it's only working with batteries. I need to test the power adapter with a load...but the easiest way to do that would probably be measuring the voltage on the pins inside the board.
Thanks for posting this BTW. I saw so many screws on the bottom. I figured a lot of em were holding the keys. I was afraid to open it up, because I figured I'd mess it up. This is very helpful!
Heather Hodge - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 37
总计 2,958
