跳转到主内容
加入维修社区 - 创建账户
Casio LK-170 Button Replacement
你所需要的
    1. Casio LK-170 Button Replacement, Button: 步骤 1 中的图像 1,2 Casio LK-170 Button Replacement, Button: 步骤 1 中的图像 2,2
      • Using a JIS-1 screwdriver, remove the seven 11 mm screws located on the back of the keyboard.
      询问修复机器人
      添加评论
    2. Casio LK-170 Button Replacement: 步骤 2 中的图像 1,1
      • Once all the screws are out, flip the keyboard over and gently pull the middle panel out.
      • Flip the middle panel up so that the component board can be seen.
      询问修复机器人
      添加评论
    3. Casio LK-170 Button Replacement: 步骤 3 中的图像 1,3 Casio LK-170 Button Replacement: 步骤 3 中的图像 2,3 Casio LK-170 Button Replacement: 步骤 3 中的图像 3,3
      • In this step, you will be removing a total of 26 screws.
      • First, you will use a PH-1 bit to remove the 17 8mm screws circled in red.
      • Next, using the same PH-1 bit, you will remove the three 8mm screws hidden under the white wires, circled in orange.
      • Then, using a JIS-1 bit, we will remove three 7mm screws from the circuit board, circled in yellow.
      • After removing the circuit board, the last three screws are revealed, circled in green. You will use the PH-1 bit to remove these last screws.
      询问修复机器人
      添加评论
    4. Casio LK-170 Button Replacement: 步骤 4 中的图像 1,1
      • Once all the screws have been removed, lift the panel and place it face down on the keys.
      • The panel is connected to the keyboard, so do not try to remove it.
      询问修复机器人
      添加评论
    5. Casio LK-170 Button Replacement: 步骤 5 中的图像 1,2 Casio LK-170 Button Replacement: 步骤 5 中的图像 2,2
      • Under the panel are the buttons. Remove them by pulling from any corner with your fingers.
      • Remove all the buttons that need to be replaced.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Eileen Tran
于01/24/17注册
108 声望
撰写一个指南
团队
Cal Poly, Team 13-2, Banghart Winter 2017 Cal Poly, Team 13-2, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S13G2
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 16
总计 821
