简介
If your display screen is not turning on or is malfunctioning then use this guide to replace your display screen on you Casio CZ-1000 synthesizer. The display screen is significant part of this synthesizer that allows you to save memory to a RAM cartridge, load RAM cartridges, and change the tone of your synthesizer. In this guide you will be provided with a step by step process on how to replace you display screen.
你所需要的
Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
