跳转到主内容
加入维修社区 - 创建账户
Casio CTK-501 Keys Replacement
你所需要的
    1. Casio CTK-501 Keys Replacement, Bottom Panel: 步骤 1 中的图像 1,2 Casio CTK-501 Keys Replacement, Bottom Panel: 步骤 1 中的图像 2,2
      • Flip the keyboard over so that the bottom is facing up.
      • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
      询问修复机器人
      添加评论
    2. Casio CTK-501 Keys Replacement: 步骤 2 中的图像 1,1
      • Remove the bottom panel by lifting and pulling it towards yourself.
      询问修复机器人
      添加评论
    3. Casio CTK-501 Keys Replacement: 步骤 3 中的图像 1,2 Casio CTK-501 Keys Replacement: 步骤 3 中的图像 2,2
      • Flip open the top half of the keyboard.
      • Set the keyboard onto the bottom half with the internal parts facing up.
      • Be careful not to let the bottom drop.
      询问修复机器人
      添加评论
    1. Casio CTK-501 Keys Replacement, Keys: 步骤 4 中的图像 1,1
      • Completely unscrew and remove the screws holding the broken string of keys in place.
      询问修复机器人
      添加评论
    2. Casio CTK-501 Keys Replacement: 步骤 5 中的图像 1,1
      • Pull up the top layer of white keys to remove them from the keyboard.
      询问修复机器人
      添加评论
    3. Casio CTK-501 Keys Replacement: 步骤 6 中的图像 1,1
      • Pull up on the last layer of white keys to remove them.
      询问修复机器人
      添加评论
    4. Casio CTK-501 Keys Replacement: 步骤 7 中的图像 1,1
      • Push the black keys toward the front of the keyboard and rotate them until they fall out of the keyboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
Jimmy Winne
于10/04/12注册
578 声望
创作了6篇指南
团队
Cal Poly, Team 9-16, Amido Fall 2012 Cal Poly, Team 9-16, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G16
4 名成员
创作了6篇指南
4指南评论
my ctk710 keybord circuit failure.... how to get new circuit in online plg help me
michael Akhil - 回复 分享
Please do you know where to get Casio CTK700/720 (or compatible) complete Keys set replacement?
Thanks in advance!
Fred from Brasil
Luis Frederico - 回复 分享
pliskers@optonline.net
Will replacing keys cure a rattle/chatter that I hear from my middle C and D keys when they are played?
pliskers - 回复 分享
I want to repair my Roland Ex 20 keyboard keys because my middle position two keys are muted.
Jit Ghosh - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 39
总计 26,368
