跳转到主内容
加入维修社区 - 创建账户
Capresso Perfectea 260 Control System Replacement
你所需要的
    1. Capresso Perfectea 260 Control System Replacement, Motherboard: 步骤 1 中的图像 1,1
      • First, take the base of the device and flip it over.
      询问修复机器人
      添加评论
    2. Capresso Perfectea 260 Control System Replacement: 步骤 2 中的图像 1,2 Capresso Perfectea 260 Control System Replacement: 步骤 2 中的图像 2,2
      • Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
      询问修复机器人
      添加评论
    3. Capresso Perfectea 260 Control System Replacement: 步骤 3 中的图像 1,1
      • Remove the two 7.5 mm Phillips #2 screws holding in the motherboard
      询问修复机器人
      添加评论
    4. Capresso Perfectea 260 Control System Replacement: 步骤 4 中的图像 1,1
      • Unplug the wire going into the side of the motherboard
      询问修复机器人
      添加评论
    5. Capresso Perfectea 260 Control System Replacement: 步骤 5 中的图像 1,2 Capresso Perfectea 260 Control System Replacement: 步骤 5 中的图像 2,2
      • Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
      • Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
      • Be careful when unplugging the wire as if it is done too forcefully it can damage the connection and make it difficult to connect a new motherboard
      询问修复机器人
      添加评论
    6. Capresso Perfectea 260 Control System Replacement: 步骤 6 中的图像 1,1
      • Lift the motherboard out of the device
      询问修复机器人
      添加评论
    1. Capresso Perfectea 260 Control System Replacement, Control System: 步骤 7 中的图像 1,2 Capresso Perfectea 260 Control System Replacement, Control System: 步骤 7 中的图像 2,2
      • Remove the two 7.5mm Phillips #2 screws from the metal frame.
      • Remove the frame from the assembly.
      询问修复机器人
      添加评论
    2. Capresso Perfectea 260 Control System Replacement: 步骤 8 中的图像 1,3 Capresso Perfectea 260 Control System Replacement: 步骤 8 中的图像 2,3 Capresso Perfectea 260 Control System Replacement: 步骤 8 中的图像 3,3
      • Remove the two 6mm fine thread Phillips #2 screws attaching the small computer chip to the metal frame.
      • Flip over and remove the 7.5 mm fine thread Phillips #2 screw from the back while holding the 5mm nut on the front securely.
      询问修复机器人
      添加评论
    3. Capresso Perfectea 260 Control System Replacement: 步骤 9 中的图像 1,3 Capresso Perfectea 260 Control System Replacement: 步骤 9 中的图像 2,3 Capresso Perfectea 260 Control System Replacement: 步骤 9 中的图像 3,3
      • Find the cable that attaches the small computer chip to the heating element connections.
      • Use the spudger to cut open the rubber coating on the latch where it clamps onto the copper tab.
      • Insert the metal spudger into the rectangular hole on the latch and push toward the tab (away from the wire) to unbend the tab.
      • Push the latch off the tab with the spudger.
      • The tab will come loose suddenly. Make sure that you apply force in a controlled manner to avoid injuring yourself or damaging the other components.
      询问修复机器人
      添加评论
    4. Capresso Perfectea 260 Control System Replacement: 步骤 10 中的图像 1,3 Capresso Perfectea 260 Control System Replacement: 步骤 10 中的图像 2,3 Capresso Perfectea 260 Control System Replacement: 步骤 10 中的图像 3,3
      • Identify the two computer chips that connect the two yellow wires to the temperature controls.
      • Remove the four 5 mm Phillips #1 screws.
      • Remove the two computer chips from their places.
      • The two computer chips are held in place by plastic interference pins. Wiggle the board free of these pins to remove.
      询问修复机器人
      添加评论
    5. Capresso Perfectea 260 Control System Replacement: 步骤 11 中的图像 1,3 Capresso Perfectea 260 Control System Replacement: 步骤 11 中的图像 2,3 Capresso Perfectea 260 Control System Replacement: 步骤 11 中的图像 3,3
      • Find the computer chip over the dial.
      • Remove the three 6mm Phillips #2 screws.
      • Remove the computer chip.
      • Remember the orientation of the computer chip on the dial and which peg goes into which hole.
      • Keep the plastic frame on the bottom of the chip attached.
      询问修复机器人
      添加评论
    6. Capresso Perfectea 260 Control System Replacement: 步骤 12 中的图像 1,1
      • Unplug the four cables on the left side of the chip.
      • Remember which cable goes to which plug.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Kenji Anzai
于04/14/15注册
594 声望
创作了4篇指南
团队
Cal Poly, Team 6-17, Maness Spring 2015 Cal Poly, Team 6-17, Maness Spring 2015 的会员
CPSU-MANESS-S15S6G17
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 43
总计 2,921
