跳转到主内容
加入维修社区 - 创建账户
Capresso Infinity Outside Casing Replacement
你所需要的
  1. Capresso Infinity Outside Casing Replacement, Metal Outside Casing: 步骤 1 中的图像 1,2 Capresso Infinity Outside Casing Replacement, Metal Outside Casing: 步骤 1 中的图像 2,2
    • Twist the top plastic container to the left counterclockwise.
    • Pull upwards to remove.
    询问修复机器人
    添加评论
  2. Capresso Infinity Outside Casing Replacement: 步骤 2 中的图像 1,3 Capresso Infinity Outside Casing Replacement: 步骤 2 中的图像 2,3 Capresso Infinity Outside Casing Replacement: 步骤 2 中的图像 3,3
    • Twist the top burr to the left counter clockwise.
    添加评论
  3. Capresso Infinity Outside Casing Replacement: 步骤 3 中的图像 1,2 Capresso Infinity Outside Casing Replacement: 步骤 3 中的图像 2,2
    • Flip entire device upside down.
    • Remove two rubber coverings on the back of the device.
    询问修复机器人
    添加评论
  4. Capresso Infinity Outside Casing Replacement: 步骤 4 中的图像 1,2 Capresso Infinity Outside Casing Replacement: 步骤 4 中的图像 2,2
    • Remove four 11.59mm T10 screws.
    • The screws will have small circular washers under them. Put them aside for reassembly.
    添加评论
  5. Capresso Infinity Outside Casing Replacement: 步骤 5 中的图像 1,3 Capresso Infinity Outside Casing Replacement: 步骤 5 中的图像 2,3 Capresso Infinity Outside Casing Replacement: 步骤 5 中的图像 3,3
    • Lift the metal outside casing off the black base.
    • Flip the outside casing forward so you have access to the inside of it.
    添加评论
  6. Capresso Infinity Outside Casing Replacement: 步骤 6 中的图像 1,3 Capresso Infinity Outside Casing Replacement: 步骤 6 中的图像 2,3 Capresso Infinity Outside Casing Replacement: 步骤 6 中的图像 3,3
    • Remove one 11.59mm T10 screw.
    • Let the green wire fall, or place somewhere so it doesn't get in the way.
    • There will be a small metal retainer and washer, put them aside for reassembly.
    添加评论
  7. Capresso Infinity Outside Casing Replacement: 步骤 7 中的图像 1,3 Capresso Infinity Outside Casing Replacement: 步骤 7 中的图像 2,3 Capresso Infinity Outside Casing Replacement: 步骤 7 中的图像 3,3
    • Remove two 11.59mm T10 screws.
    询问修复机器人
    添加评论
  8. Capresso Infinity Outside Casing Replacement: 步骤 8 中的图像 1,2 Capresso Infinity Outside Casing Replacement: 步骤 8 中的图像 2,2
    • Remove the time/on switch by pulling upwards.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Nina Mackin
于10/09/18注册
555 声望
创作了2篇指南
团队
USF Tampa, Team S1-G1, Leahy Fall 2018 USF Tampa, Team S1-G1, Leahy Fall 2018 的会员
USFT-LEAHY-F18S1G1
4 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 9
过去 30 天: 29
总计 1,991
