跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot SX60 HS Back Panel Replacement
你所需要的
    1. Canon PowerShot SX60 HS Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Make sure to power off the device before completing any more steps.
      • Remove the battery by releasing the orange clip in the battery compartment.
      询问修复机器人
      添加评论
    2. Canon PowerShot SX60 HS Back Panel Replacement: 步骤 2 中的图像 1,2 Canon PowerShot SX60 HS Back Panel Replacement: 步骤 2 中的图像 2,2
      • Remove the rubber eye piece by pulling it back.
      • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the side of the viewfinder.
      添加评论
    3. Canon PowerShot SX60 HS Back Panel Replacement: 步骤 3 中的图像 1,2 Canon PowerShot SX60 HS Back Panel Replacement: 步骤 3 中的图像 2,2
      • Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
      • Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
      • Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
      • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
      询问修复机器人
      添加评论
    4. Canon PowerShot SX60 HS Back Panel Replacement: 步骤 4 中的图像 1,2 Canon PowerShot SX60 HS Back Panel Replacement: 步骤 4 中的图像 2,2
      在这个步骤中使用的工具:
      • Ensure the LCD screen is swung fully to the left before taking off the back panel.
      • Use the iFixit opening tool to pry off the back panel.
      • Don't completely pull off the back panel because there is still a ribbon attached.
      • Use the black spudger to unclip the ribbon located behind the battery compartment. Then remove it using the nylon tipped tweezers.
      • Once the ribbon is unplugged, remove the back panel from the camera body.
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 33
总计 1,179
