跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot S500 Battery Casing Replacement
你所需要的
    1. Canon PowerShot S500 Battery Casing Replacement, Front and Rear Casing : 步骤 1 中的图像 1,2 Canon PowerShot S500 Battery Casing Replacement, Front and Rear Casing : 步骤 1 中的图像 2,2
      • Unscrew five Phillips screws using a #0 Phillips screwdriver.
      • One screw is on upper right corner of the back panel.
      • The other four screws are on the bottom of the camera.
      询问修复机器人
      添加评论
    2. Canon PowerShot S500 Battery Casing Replacement: 步骤 2 中的图像 1,1
      • Open the memory card cover by moving the slide switch toward the top end of of the camera.
      • Remove the memory card from the slot.
      询问修复机器人
      添加评论
    3. Canon PowerShot S500 Battery Casing Replacement: 步骤 3 中的图像 1,1
      • Remove the rear cover from the rest of the camera.
      • This may require gentle rocking of the case to free it.
      询问修复机器人
      添加评论
    4. Canon PowerShot S500 Battery Casing Replacement: 步骤 4 中的图像 1,2 Canon PowerShot S500 Battery Casing Replacement: 步骤 4 中的图像 2,2
      • Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
      询问修复机器人
      添加评论
    5. Canon PowerShot S500 Battery Casing Replacement: 步骤 5 中的图像 1,1
      • Free the front cover from the rest of the camera.
      • The cover may require gentle rocking to remove.
      询问修复机器人
      添加评论
    1. Canon PowerShot S500 Battery Casing Replacement, LCD: 步骤 6 中的图像 1,1
      • Unscrew two Phillips screws above the LCD using a #0 Phillips screwdriver.
      询问修复机器人
      添加评论
    2. Canon PowerShot S500 Battery Casing Replacement: 步骤 7 中的图像 1,1
      • Gently separate the top of LCD from the rest of the camera using your thumb.
      • Be careful not pull the LCD too far because of the ribbon cable connection.
      • Place the Spudger in the hole of the electrical ribbon.
      • Gently pull the ribbon down using the Spudger until it is free from the camera but still connected to the LCD.
      • The LCD will still be connected to the rest of the camera
      询问修复机器人
      添加评论
    3. Canon PowerShot S500 Battery Casing Replacement: 步骤 8 中的图像 1,2 Canon PowerShot S500 Battery Casing Replacement: 步骤 8 中的图像 2,2
      • Unscrew single Phillips screw with a #0 Phillips screwdriver.
      • Free the bottom panel and attached ribbon from the rest of the camera.
      • Be careful not to damage the ribbon.
      询问修复机器人
      添加评论
    4. Canon PowerShot S500 Battery Casing Replacement: 步骤 9 中的图像 1,1
      • Turn over the camera.
      • Lift the clear plastic from the face of the camera, peeling the adhesive just below the zoom lens.
      • The plastic will still be connected on the left side.
      询问修复机器人
      添加评论
    5. Canon PowerShot S500 Battery Casing Replacement: 步骤 10 中的图像 1,1
      • Place the Spudger between the orange ribbon and the black ribbon gate.
      • Lift the ribbon gate using the Spudger.
      询问修复机器人
      添加评论
    6. Canon PowerShot S500 Battery Casing Replacement: 步骤 11 中的图像 1,1
      • Place the Spudger in the corner of the ribbon above the hole.
      • Remove the ribbon from the ribbon gate by pulling the Spudger away from the gate.
      询问修复机器人
      添加评论
    7. Canon PowerShot S500 Battery Casing Replacement: 步骤 12 中的图像 1,1
      • Free this ribbon and the bottom panel from the rest of the camera.
      询问修复机器人
      添加评论
    8. Canon PowerShot S500 Battery Casing Replacement: 步骤 13 中的图像 1,1
      • Turn the camera over so you can see the LCD.
      • Remove single Phillips screw below the LCD using a #0 Phillips screwdriver.
      询问修复机器人
      添加评论
    9. Canon PowerShot S500 Battery Casing Replacement: 步骤 14 中的图像 1,1
      • Lift the blue ribbon gate using the Spudger.
      询问修复机器人
      添加评论
    10. Canon PowerShot S500 Battery Casing Replacement: 步骤 15 中的图像 1,1
      • Insert the Spudger into the hole of the ribbon.
      • Move the Spudger away from the gate to fully remove ribbon.
      询问修复机器人
      添加评论
    11. Canon PowerShot S500 Battery Casing Replacement: 步骤 16 中的图像 1,1
      • Lift the LCD away from the rest of the camera.
      询问修复机器人
      添加评论
    1. Canon PowerShot S500 Battery Casing Replacement, Logic Board: 步骤 17 中的图像 1,2 Canon PowerShot S500 Battery Casing Replacement, Logic Board: 步骤 17 中的图像 2,2
      • Lift off the capture button by wiggling it back and forth while pulling upward.
      • Be careful not to damage the two clips.
      询问修复机器人
      添加评论
    2. Canon PowerShot S500 Battery Casing Replacement: 步骤 18 中的图像 1,2 Canon PowerShot S500 Battery Casing Replacement: 步骤 18 中的图像 2,2
      • Flip open the four ribbon gates using the Spudger.
      • Gently pull out the ribbon cables from the gates using the Spudger.
      询问修复机器人
      添加评论
    3. Canon PowerShot S500 Battery Casing Replacement: 步骤 19 中的图像 1,1
      • Unscrew the four Phillips screws using a #0 Phillips screwdriver.
      询问修复机器人
      添加评论
    4. Canon PowerShot S500 Battery Casing Replacement: 步骤 20 中的图像 1,2 Canon PowerShot S500 Battery Casing Replacement: 步骤 20 中的图像 2,2
      • Gently lift the logic board.
      • Be careful not to pull too hard and damage the white ribbon cable.
      • Place the Spudger so that it is between the logic board, the white ribbon cable, and the rest of the camera.
      • Remove the white ribbon cable by pulling the Spudger away from the camera, keeping it parallel to the logic board.
      询问修复机器人
      添加评论
    5. Canon PowerShot S500 Battery Casing Replacement: 步骤 21 中的图像 1,1
      在这个步骤中使用的工具:
      • Lay the logic board back down so that it is resting on the body of the camera.
      • Pull the two plugs (white and green) out to the right from the logic board using the tweezers.
      询问修复机器人
      添加评论
    6. Canon PowerShot S500 Battery Casing Replacement: 步骤 22 中的图像 1,2 Canon PowerShot S500 Battery Casing Replacement: 步骤 22 中的图像 2,2
      • We're now ready to begin the desoldering process. You'll need a soldering iron, solder, and desoldering wick. You should be able to find these items at a Radio Shack if you don't already have them.
      • Please do not perform this step if you are not comfortable or have previous experience with soldering. Doing so, could cause severe damage to your camera.
      • Desolder the two soldered ribbon cables attached to the logic board.
      询问修复机器人
      添加评论
    7. Canon PowerShot S500 Battery Casing Replacement: 步骤 23 中的图像 1,1
      • Free the logic board from the rest of the camera.
      询问修复机器人
      添加评论
    1. Canon PowerShot S500 Battery Casing Replacement, Breakdown to Three Parts: 步骤 24 中的图像 1,1
      • Turn the camera over so that the back is facing you.
      • Unscrew the three Phillips screws using a #0 Phillips screwdriver.
      询问修复机器人
      添加评论
    2. Canon PowerShot S500 Battery Casing Replacement: 步骤 25 中的图像 1,2 Canon PowerShot S500 Battery Casing Replacement: 步骤 25 中的图像 2,2
      • Lift off the Memory Card casing, sliding the ribbon cable through the camera. Keep pulling until the Memory Card and ribbon cable have been removed from the camera.
      • Note that the ribbon cable is coming from the external front portion of the camera. Make sure that the ribbon cable will not get caught on anything.
      询问修复机器人
      添加评论
    3. Canon PowerShot S500 Battery Casing Replacement: 步骤 26 中的图像 1,2 Canon PowerShot S500 Battery Casing Replacement: 步骤 26 中的图像 2,2
      • Unscrew one Phillips screws from the side and three Phillips screws from the back panel using a #0 Phillips screwdriver.
      询问修复机器人
      添加评论
    4. Canon PowerShot S500 Battery Casing Replacement: 步骤 27 中的图像 1,3 Canon PowerShot S500 Battery Casing Replacement: 步骤 27 中的图像 2,3 Canon PowerShot S500 Battery Casing Replacement: 步骤 27 中的图像 3,3
      • Firmly push on the back of the zoom lens, removing it from the left portion of the camera.
      • Lift the zoom lens away from the left portion of the camera so that there are three components connected by a ribbon cables.
      • Be careful not to tear the ribbon cables.
      询问修复机器人
      添加评论
    5. Canon PowerShot S500 Battery Casing Replacement: 步骤 28 中的图像 1,1
      • The camera should now be able to be set in this orientation without too much stress on the cables.
      • The clear plastic is still attached to the battery casing.
      询问修复机器人
      添加评论
    6. Canon PowerShot S500 Battery Casing Replacement: 步骤 29 中的图像 1,2 Canon PowerShot S500 Battery Casing Replacement: 步骤 29 中的图像 2,2
      在这个步骤中使用的工具:
      • Locate the ribbon cable going from the battery case to the flash assembly.
      • Remove the plug from the ribbon cable using the tweezers.
      • The flash assembly is now free from the rest of the camera.
      询问修复机器人
      添加评论
    7. Canon PowerShot S500 Battery Casing Replacement: 步骤 30 中的图像 1,1
      • Pick up the remaining battery casing and zoom lens.
      • Pull off the clear plastic.
      • The clear plastic is secured by adhesive along the bottom edge and a small hook.
      询问修复机器人
      添加评论
    8. Canon PowerShot S500 Battery Casing Replacement: 步骤 31 中的图像 1,1
      • Lift the zoom lens off of the battery casing.
      • The back of the circuits are attached to the battery casing by a light adhesive, which can be removed with a slight pull upwards.
      询问修复机器人
      添加评论
    9. Canon PowerShot S500 Battery Casing Replacement: 步骤 32 中的图像 1,1
      • The remaining pieces from left to right are: the battery casing, zoom lens and flash assembly.
      询问修复机器人
      添加评论
    1. Canon PowerShot S500 Battery Casing Replacement, Battery Casing: 步骤 33 中的图像 1,1
      • Check the battery terminals for any corrosive material or bad connections.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Nathan Balcom
于01/21/10注册
102 声望
创作了8篇指南
团队
Cal Poly, Team 16-28, Maness Winter 2010 Cal Poly, Team 16-28, Maness Winter 2010 的会员
CPSU-MANESS-W10S16G28
4 名成员
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 47
总计 3,649
