跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot S50 LCD Screen Replacement
你所需要的
    1. Canon PowerShot S50 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,2 Canon PowerShot S50 LCD Screen Replacement, Battery: 步骤 1 中的图像 2,2
      • Place camera LCD side up and press up on the battery door.
      • Let it swing open until you can see the battery inside.
      询问修复机器人
      添加评论
    2. Canon PowerShot S50 LCD Screen Replacement: 步骤 2 中的图像 1,1
      • Press down on the orange plastic.
      • This will gently eject the battery from its compartment.
      询问修复机器人
      添加评论
    3. Canon PowerShot S50 LCD Screen Replacement: 步骤 3 中的图像 1,2 Canon PowerShot S50 LCD Screen Replacement: 步骤 3 中的图像 2,2
      • Holding the edges, slide out the battery.
      询问修复机器人
      添加评论
    1. Canon PowerShot S50 LCD Screen Replacement, Front Panel/Battery Door: 步骤 4 中的图像 1,1
      • Look at the camera from the side with the lanyard and 4 screws.
      • Remove the two 3.4 mm screws on the metallic colored part.
      询问修复机器人
      添加评论
    2. Canon PowerShot S50 LCD Screen Replacement: 步骤 5 中的图像 1,1
      • Remove the 3mm screw on the top left.
      • NOTE: When reassembling, it is helpful to put the top screw back in before placing the front cover back on the camera.
      • Now remove the 5.3mm screw on the bottom.
      询问修复机器人
      添加评论
    3. Canon PowerShot S50 LCD Screen Replacement: 步骤 6 中的图像 1,1
      • Place the camera LCD side down.
      • Remove the two 5.3mm screws by the battery door.
      询问修复机器人
      添加评论
    4. Canon PowerShot S50 LCD Screen Replacement: 步骤 7 中的图像 1,1
      • Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
      • Make sure to keep these screws separate from the previous 5.3 mm screws.
      询问修复机器人
      添加评论
    5. Canon PowerShot S50 LCD Screen Replacement: 步骤 8 中的图像 1,1
      • Stand the camera back up.
      • Remove the two 3.6mm screws on the side with the A/V Out port.
      询问修复机器人
      添加评论
    6. Canon PowerShot S50 LCD Screen Replacement: 步骤 9 中的图像 1,1
      • Lift open the rubber flap covering the A/V Out port.
      • Remove the 3.4mm screw in the center.
      • During reassembly, put the A/V out rubber door on before replacing the front panel of the camera
      询问修复机器人
      添加评论
    7. Canon PowerShot S50 LCD Screen Replacement: 步骤 10 中的图像 1,1
      • Use a spudger and gently open up the front panel of the camera.
      • A thin plastic ribbon will stay connected by a brown piece to front panel of the camera.
      询问修复机器人
      添加评论
    8. Canon PowerShot S50 LCD Screen Replacement: 步骤 11 中的图像 1,1
      • There will be a brown plastic piece keeping the thin plastic ribbon in place.
      • Use the spudger to pull out the brown plastic piece attached to the orange plastic.
      询问修复机器人
      添加评论
    9. Canon PowerShot S50 LCD Screen Replacement: 步骤 12 中的图像 1,1
      在这个步骤中使用的工具:
      • Use a pair of tweezers and remove the metal piece inside the camera.
      询问修复机器人
      添加评论
    10. Canon PowerShot S50 LCD Screen Replacement: 步骤 13 中的图像 1,1
      • Remove the battery door
      • NOTE: Putting this back on requires aligning the spring on the back of the door with the hole on the camera
      询问修复机器人
      添加评论
    1. Canon PowerShot S50 LCD Screen Replacement, Right Motherboard: 步骤 14 中的图像 1,1
      • Disconnect the two plastic ribbons on the lower half of the right motherboard.
      • NOTE: You will have to lift up the brown plastic piece in order to pull out the second ribbon wire.
      询问修复机器人
      添加评论
    2. Canon PowerShot S50 LCD Screen Replacement: 步骤 15 中的图像 1,1
      • Remove the two 3.4mm screws on the right motherboard.
      询问修复机器人
      添加评论
    3. Canon PowerShot S50 LCD Screen Replacement: 步骤 16 中的图像 1,1
      • Disconnect the two wired plugs below the flash.
      询问修复机器人
      添加评论
    4. Canon PowerShot S50 LCD Screen Replacement: 步骤 17 中的图像 1,1
      • Disconnect the wired plug at the bottom of the right motherboard.
      询问修复机器人
      添加评论
    5. Canon PowerShot S50 LCD Screen Replacement: 步骤 18 中的图像 1,1
      在这个步骤中使用的工具:
      • Use a pair of tweezers to pull the right motherboard away from the main body of the camera.
      询问修复机器人
      添加评论
    1. Canon PowerShot S50 LCD Screen Replacement, Outer Casing: 步骤 19 中的图像 1,1
      • Using a spudger, gently separate the back panel from the rest of the camera and remove it.
      询问修复机器人
      添加评论
    1. Canon PowerShot S50 LCD Screen Replacement, LCD Screen: 步骤 20 中的图像 1,1
      • Remove the 2.6mm screw on the bottom of the camera located directly under the LCD screen.
      • This screw should be holding two pieces of orange film down.
      • When replacing this screw, make sure that the orange film is secure below it before screwing it in.
      询问修复机器人
      添加评论
    2. Canon PowerShot S50 LCD Screen Replacement: 步骤 21 中的图像 1,1
      • Disconnect the film from the bottom of the camera under the LCD Screen.
      询问修复机器人
      添加评论
    3. Canon PowerShot S50 LCD Screen Replacement: 步骤 22 中的图像 1,1
      • Remove the 3.3mm screw on the bottom left of the LCD screen.
      询问修复机器人
      添加评论
    4. Canon PowerShot S50 LCD Screen Replacement: 步骤 23 中的图像 1,1
      • Remove the 2.4mm screw located just to the upper right of the LCD Screen.
      询问修复机器人
      添加评论
    5. Canon PowerShot S50 LCD Screen Replacement: 步骤 24 中的图像 1,1
      • Gently remove the LCD Screen.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Jacob
于03/29/12注册
16 声望
创作了3篇指南
团队
Cal Poly, Team 7-34, Maness Spring 2012 Cal Poly, Team 7-34, Maness Spring 2012 的会员
CPSU-MANESS-S12S7G34
5 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 35
总计 2,079
