简介
The flash of the Canon PowerShot G3 camera is operated by the discharge of a capacitor. A capacitor is an energy storing device that stores a charge between two conducting plates. Before the capacitor can discharge, it must be charged by the battery.
Note:
1.) There are many screws to be removed before you can reach the capacitor.
2.) To install a new capacitor you must know how to solder wires to the capacitor.
3.) Do not continue unless you have a magnetic pad to place the screws and a soldering iron.
你所需要的
Start to remove all of the screws around the camera: from the front, back, sides, and bottom.
Use a spudger, or other thin object, to remove the capacitor from the housing. (Image 2)
To remove the red and yellow wires connected to the capacitor, use a soldering iron to heat up the solder and a vacuum to suck up the solder. Any other methods you know of will also work.
Take the capacitor to you local electronics store or order another capacitor online by reading the capacity off of the side of the capacitor. It should be in microFarads (µF).
Once you have a new capacitor, solder on the red and yellow wires to the same place as the old capacitor.
