跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot G11 LCD Screen Replacement
你所需要的
    1. Canon PowerShot G11 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
      • Remove the two 3.10mm Phillips #00 screws from the LCD case.
      询问修复机器人
      添加评论
    2. Canon PowerShot G11 LCD Screen Replacement: 步骤 2 中的图像 1,1
      • Open the LCD screen and turn it so the screen is facing the bottom of the camera, the screw is on the bottom of the LCD screen.
      • Remove the 3.10mm Philips #00 screw from the bottom end of the LCD screen.
      询问修复机器人
      添加评论
    3. Canon PowerShot G11 LCD Screen Replacement: 步骤 3 中的图像 1,1
      • Turn the LCD so that the screen is facing the top of the camera, the screw you need is on the bottom of the LCD screen.
      • Remove the 3.10mm Philips #00 screw.
      询问修复机器人
      添加评论
    4. Canon PowerShot G11 LCD Screen Replacement: 步骤 4 中的图像 1,1
      • Use the plastic opening tool on the indent at the top of the LCD screen to pop off the LCD case.
      询问修复机器人
      添加评论
    5. Canon PowerShot G11 LCD Screen Replacement: 步骤 5 中的图像 1,2 Canon PowerShot G11 LCD Screen Replacement: 步骤 5 中的图像 2,2
      • Remove the 2.22mm Phillips #00 screw that is located next to the indent handle.
      • When the top screw is removed the small metal bracket will fall out, when reassembling the LCD screen remember to put it back on.
      询问修复机器人
      添加评论
    6. Canon PowerShot G11 LCD Screen Replacement: 步骤 6 中的图像 1,2 Canon PowerShot G11 LCD Screen Replacement: 步骤 6 中的图像 2,2
      • Once the back panel is off remove the two 3.13mm Philips #00 screws.
      • There are magnets next the screws so when you reassemble the LCD screen make note of this, they will move the screws.
      询问修复机器人
      添加评论
    7. Canon PowerShot G11 LCD Screen Replacement: 步骤 7 中的图像 1,2 Canon PowerShot G11 LCD Screen Replacement: 步骤 7 中的图像 2,2
      • On the bottom of the LCD screen carefully turn it so the screen is facing the top of the camera and remove the 2.22mm Phillips #00 screw.
      • Once this screw comes off the top case will come off and the LCD screen will be held by only the wires so handle it carefully so as not to damage the wires.
      询问修复机器人
      添加评论
    8. Canon PowerShot G11 LCD Screen Replacement: 步骤 8 中的图像 1,3 Canon PowerShot G11 LCD Screen Replacement: 步骤 8 中的图像 2,3 Canon PowerShot G11 LCD Screen Replacement: 步骤 8 中的图像 3,3
      • Remove the screen from the base of the LCD.
      • Do not pull because the wire strip is still attached to the LCD base.
      • Do not remove this wire, it is not needed when replacing the screen.
      添加评论
    9. Canon PowerShot G11 LCD Screen Replacement: 步骤 9 中的图像 1,3 Canon PowerShot G11 LCD Screen Replacement: 步骤 9 中的图像 2,3 Canon PowerShot G11 LCD Screen Replacement: 步骤 9 中的图像 3,3
      在这个步骤中使用的工具:
      • Use the tweezers to lift the small brown plastic snap before you remove the wire.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
USF Tampa, Team 5-6, Brown Winter 2015 USF Tampa, Team 5-6, Brown Winter 2015 的会员
USFT-BROWN-W15S5G6
3 名成员
创作了6篇指南
4指南评论
Did this. The first time i put it ack together it did not work , Had totake apart and adjust wires okay after put bake together again.
Jim Murphy - 回复 分享
Followed these instructions and the result is excellent. Well done, and thanks very much. Saved me buying another camera!
Steve Rayner - 回复 分享
How do you get a new screen on there?
Jacob Fields - 回复 分享
Faltan planos. Por arte de magia el lcd aparece a la izquierda de varias fotos cuando debería estar debajo de la placa verde. Perdonen, muy mal explicado.
jlmgbaquero007 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 75
总计 5,935
