跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot A630 Trigger Button Replacement
你所需要的
    1. Canon PowerShot A630 Trigger Button Replacement, Front Panel: 步骤 1 中的图像 1,2 Canon PowerShot A630 Trigger Button Replacement, Front Panel: 步骤 1 中的图像 2,2
      • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
      • Remove batteries.
      询问修复机器人
      添加评论
    2. Canon PowerShot A630 Trigger Button Replacement: 步骤 2 中的图像 1,2 Canon PowerShot A630 Trigger Button Replacement: 步骤 2 中的图像 2,2
      • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
      • Gently pull off side-panel to remove it.
      询问修复机器人
      添加评论
    3. Canon PowerShot A630 Trigger Button Replacement: 步骤 3 中的图像 1,1
      • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    4. Canon PowerShot A630 Trigger Button Replacement: 步骤 4 中的图像 1,2 Canon PowerShot A630 Trigger Button Replacement: 步骤 4 中的图像 2,2
      • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
      • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    5. Canon PowerShot A630 Trigger Button Replacement: 步骤 5 中的图像 1,2 Canon PowerShot A630 Trigger Button Replacement: 步骤 5 中的图像 2,2
      • Open 'DIGITAL A/V OUT' door on camera.
      询问修复机器人
      添加评论
    6. Canon PowerShot A630 Trigger Button Replacement: 步骤 6 中的图像 1,1
      • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
      • The top panel will not completely detach.
      询问修复机器人
      添加评论
    7. Canon PowerShot A630 Trigger Button Replacement: 步骤 7 中的图像 1,2 Canon PowerShot A630 Trigger Button Replacement: 步骤 7 中的图像 2,2
      • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
      • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
      添加评论
    1. Canon PowerShot A630 Trigger Button Replacement, Trigger Button: 步骤 8 中的图像 1,1
      • Use the spudger to gently pull back the retaining clip and pull the ribbon out
      • The top panel should now be completely detached from the camera
      • Applying to much force to the spudger may damage the retaining clip
      询问修复机器人
      添加评论
    2. Canon PowerShot A630 Trigger Button Replacement: 步骤 9 中的图像 1,1
      • Remove the two screws holding down the metal frame using the Phillips #00 screwdriver
      询问修复机器人
      添加评论
    3. Canon PowerShot A630 Trigger Button Replacement: 步骤 10 中的图像 1,1
      • Lift up the metal frame to expose the two screws located under the trigger button.
      • Remove the two screws using Phillips #00 screwdriver
      询问修复机器人
      添加评论
    4. Canon PowerShot A630 Trigger Button Replacement: 步骤 11 中的图像 1,2 Canon PowerShot A630 Trigger Button Replacement: 步骤 11 中的图像 2,2
      • Trigger button should fall out
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Clemson, Team 2-5, Benson Fall 2014 Clemson, Team 2-5, Benson Fall 2014 的会员
CLEM-BENSON-F14S2G5
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 28
总计 1,051
