本指南有最近更改,您可查看未经巡查的最新版本。
简介
First you will remove the batteries and back cover of the camera. You will unscrew the LCD. You will then remove the ribbon attached to the logic board. Finally you will unsolder the LCD from the logic board.
你所需要的
Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
With the LCD pulled back in one hand and using a blue iPod opener tool, pull the black retaining clip up and remove the ribbon.
Use tweezers to unsolder the wires from the bottom left corner on the back of the LCD.
Remove the solder from the wires.
另外一个人完成了本指南。
