当前版本的文档还未经巡查,您可以查看最新的已查核版本。
The battery hatch is on the bottom of the camera.
CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
While the switch is pushed forward, pull the cover away from the camera.
This camera requires AA batteries.
To remove batteries, simply allow them to fall out of the camera.
Use a fingernail to lift the clock battery out of the camera.
CAUTION: The LCD is connected to the motherboard with different wires and a ribbon. Using too much force may disconnect these parts.
Gently lift the screen from the motherboard.
Keep the LCD pulled back in one hand.
Desolder the wires from the back of the LCD located in the bottom left corner.
Remove the solder from the wires.
Separate the LCD from the rest of the camera.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
