跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot A460 LCD Screen Replacement
你所需要的
    1. Canon PowerShot A460 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
      • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
      • While still holding the switch, pull the cover down, allowing it to release and open.
      询问修复机器人
      添加评论
    2. Canon PowerShot A460 LCD Screen Replacement: 步骤 2 中的图像 1,1
      • Tilt the camera slightly to allow the batteries to fall out.
      询问修复机器人
      添加评论
    3. Canon PowerShot A460 LCD Screen Replacement: 步骤 3 中的图像 1,1
      • Press on and release the memory card to eject it.
      询问修复机器人
      添加评论
    1. Canon PowerShot A460 LCD Screen Replacement, Front Casing: 步骤 4 中的图像 1,1
      • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
      • Make sure to keep the different size screws organized to make reassembling the camera simpler.
      询问修复机器人
      添加评论
    2. Canon PowerShot A460 LCD Screen Replacement: 步骤 5 中的图像 1,1
      • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
      询问修复机器人
      添加评论
    3. Canon PowerShot A460 LCD Screen Replacement: 步骤 6 中的图像 1,1
      • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
      询问修复机器人
      添加评论
    4. Canon PowerShot A460 LCD Screen Replacement: 步骤 7 中的图像 1,1
      • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
      询问修复机器人
      添加评论
    5. Canon PowerShot A460 LCD Screen Replacement: 步骤 8 中的图像 1,2 Canon PowerShot A460 LCD Screen Replacement: 步骤 8 中的图像 2,2
      • Remove the second battery cover on the bottom of camera.
      • Take the silver battery out of the camera.
      询问修复机器人
      添加评论
    6. Canon PowerShot A460 LCD Screen Replacement: 步骤 9 中的图像 1,3 Canon PowerShot A460 LCD Screen Replacement: 步骤 9 中的图像 2,3 Canon PowerShot A460 LCD Screen Replacement: 步骤 9 中的图像 3,3
      • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
      • Remove the light grey, plastic piece.
      • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
      询问修复机器人
      添加评论
    7. Canon PowerShot A460 LCD Screen Replacement: 步骤 10 中的图像 1,3 Canon PowerShot A460 LCD Screen Replacement: 步骤 10 中的图像 2,3 Canon PowerShot A460 LCD Screen Replacement: 步骤 10 中的图像 3,3
      • Slightly pull on each side of the camera. It should loosen up and come apart.
      • If it does not pull apart right away, use a little more force.
      • Do not give up!
      询问修复机器人
      添加评论
    1. Canon PowerShot A460 LCD Screen Replacement, Back Casing: 步骤 11 中的图像 1,1
      • Remove the back case of the camera by pulling from the top.
      • Be careful when pulling off the case. There is a delicate gold ribbon connecting the bottom of the camera to the back case.
      询问修复机器人
      添加评论
    1. Canon PowerShot A460 LCD Screen Replacement, LCD Screen: 步骤 12 中的图像 1,1
      • Remove the 4mm Phillips #00 screw from above the ribbon.
      询问修复机器人
      添加评论
    2. Canon PowerShot A460 LCD Screen Replacement: 步骤 13 中的图像 1,1
      • Gently peel off the blue tape on the top of the LCD screen.
      询问修复机器人
      添加评论
    3. Canon PowerShot A460 LCD Screen Replacement: 步骤 14 中的图像 1,1
      • Remove the 4mm Phillips #00 screw previously concealed by the blue tape.
      询问修复机器人
      添加评论
    4. Canon PowerShot A460 LCD Screen Replacement: 步骤 15 中的图像 1,1
      • Gently lift the LCD screen off of the front casing by pulling up a tab on the side of the camera.
      询问修复机器人
      添加评论
    5. Canon PowerShot A460 LCD Screen Replacement: 步骤 16 中的图像 1,1
      • Using a spudger, lift the grey tabs to allow the ribbon to slide out.
      添加评论
    6. Canon PowerShot A460 LCD Screen Replacement: 步骤 17 中的图像 1,1
      • Since the tabs have been lifted, the ribbon should now slide out out easily.
      • Be careful not to distort the ribbon in any way.
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Alex
于01/18/13注册
112 声望
创作了2篇指南
团队
Cal Poly, Team 19-42, Regan Winter 2013 Cal Poly, Team 19-42, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G42
4 名成员
创作了18篇指南
2指南评论
Thanks for this super documented guide.
I did it!! I found a second hand lcd on Ebay.
Now my camera is working again.
Super DIY guide!! Thanks a lot!!
Pierre - 回复 分享
Explained in detail, very clear, easy to understand. I just unpacked it for the first time. Still able to do as told. Thank you.
Rachsuthee Waiprib - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 46
总计 2,189
