跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot A460 Back Casing Replacement
你所需要的
    1. Canon PowerShot A460 Back Casing Replacement, Battery: 步骤 1 中的图像 1,1
      • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
      • While still holding the switch, pull the cover down, allowing it to release and open.
      询问修复机器人
      添加评论
    2. Canon PowerShot A460 Back Casing Replacement: 步骤 2 中的图像 1,1
      • Tilt the camera slightly to allow the batteries to fall out.
      询问修复机器人
      添加评论
    3. Canon PowerShot A460 Back Casing Replacement: 步骤 3 中的图像 1,1
      • Press on and release the memory card to eject it.
      询问修复机器人
      添加评论
    1. Canon PowerShot A460 Back Casing Replacement, Front Casing: 步骤 4 中的图像 1,1
      • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
      • Make sure to keep the different size screws organized to make reassembling the camera simpler.
      询问修复机器人
      添加评论
    2. Canon PowerShot A460 Back Casing Replacement: 步骤 5 中的图像 1,1
      • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
      询问修复机器人
      添加评论
    3. Canon PowerShot A460 Back Casing Replacement: 步骤 6 中的图像 1,1
      • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
      询问修复机器人
      添加评论
    4. Canon PowerShot A460 Back Casing Replacement: 步骤 7 中的图像 1,1
      • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
      询问修复机器人
      添加评论
    5. Canon PowerShot A460 Back Casing Replacement: 步骤 8 中的图像 1,2 Canon PowerShot A460 Back Casing Replacement: 步骤 8 中的图像 2,2
      • Remove the second battery cover on the bottom of camera.
      • Take the silver battery out of the camera.
      询问修复机器人
      添加评论
    6. Canon PowerShot A460 Back Casing Replacement: 步骤 9 中的图像 1,3 Canon PowerShot A460 Back Casing Replacement: 步骤 9 中的图像 2,3 Canon PowerShot A460 Back Casing Replacement: 步骤 9 中的图像 3,3
      • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
      • Remove the light grey, plastic piece.
      • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
      询问修复机器人
      添加评论
    7. Canon PowerShot A460 Back Casing Replacement: 步骤 10 中的图像 1,3 Canon PowerShot A460 Back Casing Replacement: 步骤 10 中的图像 2,3 Canon PowerShot A460 Back Casing Replacement: 步骤 10 中的图像 3,3
      • Slightly pull on each side of the camera. It should loosen up and come apart.
      • If it does not pull apart right away, use a little more force.
      • Do not give up!
      询问修复机器人
      添加评论
    1. Canon PowerShot A460 Back Casing Replacement, Back Casing: 步骤 11 中的图像 1,1
      • Remove the back case of the camera by pulling from the top.
      • Be careful when pulling off the case. There is a delicate gold ribbon connecting the bottom of the camera to the back case.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 19-42, Regan Winter 2013 Cal Poly, Team 19-42, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G42
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 62
总计 4,124
