跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot A2500 LCD Display Replacement
你所需要的
    1. Canon PowerShot A2500 LCD Display Replacement, Body Casing and Faceplate: 步骤 1 中的图像 1,2 Canon PowerShot A2500 LCD Display Replacement, Body Casing and Faceplate: 步骤 1 中的图像 2,2
      • Remove the knot holding the wrist lanyard onto the camera
      询问修复机器人
      添加评论
    2. Canon PowerShot A2500 LCD Display Replacement: 步骤 2 中的图像 1,1
      • Open the latch at the bottom corner of the device to reveal the battery and SD card housing.
      • There is an orange latch holding the battery in place which must be pushed back in order to free the battery.
      • Once the battery is removed push the SD card and this will activate a spring ejecting the card from the camera.
      询问修复机器人
      添加评论
    3. Canon PowerShot A2500 LCD Display Replacement: 步骤 3 中的图像 1,3 Canon PowerShot A2500 LCD Display Replacement: 步骤 3 中的图像 2,3 Canon PowerShot A2500 LCD Display Replacement: 步骤 3 中的图像 3,3
      • Remove the 6 Phillips #00 exterior screws from the camera. Two are located on the bottom and two are located on either side as shown. Notice that one of the screws is under the AV Out Digital flap on the side. All exterior screws should be 2.4mm in length
      询问修复机器人
      添加评论
    4. Canon PowerShot A2500 LCD Display Replacement: 步骤 4 中的图像 1,3 Canon PowerShot A2500 LCD Display Replacement: 步骤 4 中的图像 2,3 Canon PowerShot A2500 LCD Display Replacement: 步骤 4 中的图像 3,3
      • Pry apart the camera casing using the plastic opening tool tool provided. Once the casing has begun to separate pull the two sides apart with your hands.
      • Be careful not to bend the plastic casing to much, as it will crack.
      询问修复机器人
      添加评论
    1. Canon PowerShot A2500 LCD Display Replacement, Buttons: 步骤 5 中的图像 1,1
      • Remove the single philips #00 screw on the button pad which are 2.2mm long. This screw is circled in red in the guide image.
      • Next, remove the two 2.4mm long screws located in between the LCD screen and the touch pad. These screws will require a Phillips #00 screwdriver.
      添加评论
    2. Canon PowerShot A2500 LCD Display Replacement: 步骤 6 中的图像 1,2 Canon PowerShot A2500 LCD Display Replacement: 步骤 6 中的图像 2,2
      • Pull the two clips off located near the power button
      • The clips are easily broken, use care while disconnecting these clips.
      询问修复机器人
      添加评论
    3. Canon PowerShot A2500 LCD Display Replacement: 步骤 7 中的图像 1,3 Canon PowerShot A2500 LCD Display Replacement: 步骤 7 中的图像 2,3 Canon PowerShot A2500 LCD Display Replacement: 步骤 7 中的图像 3,3
      • Remove the circuit ribbon connecting the flash to the camera in order to proceed to the next instruction.
      • Carefully pull out the circuit ribbon from the camera which should be the last piece holding the button pad onto the camera.
      添加评论
    1. Canon PowerShot A2500 LCD Display Replacement, LCD Display: 步骤 8 中的图像 1,1
      • Lift the tab at the end of the ribbon
      • Disconnect the ribbon from the circuitboard
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 3-4, Duarte Spring 2015 UMass Dartmouth, Team 3-4, Duarte Spring 2015 的会员
UMASSD-DUARTE-S15S3G4
4 名成员
创作了12篇指南
2指南评论
There seams to be a step missing on step 6 . As there is a screw that has to be removed covered to the left of button on top of camera.
Jack Banks - 回复 分享
There seams to be a step missing on step 6...
Vinicius Maia - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 11
过去 30 天: 55
总计 2,036
