跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot A2500 Flash Component Replacement
你所需要的
    1. Canon PowerShot A2500 Flash Component Replacement, Body Casing and Faceplate: 步骤 1 中的图像 1,2 Canon PowerShot A2500 Flash Component Replacement, Body Casing and Faceplate: 步骤 1 中的图像 2,2
      • Remove the knot holding the wrist lanyard onto the camera
      询问修复机器人
      添加评论
    2. Canon PowerShot A2500 Flash Component Replacement: 步骤 2 中的图像 1,1
      • Open the latch at the bottom corner of the device to reveal the battery and SD card housing.
      • There is an orange latch holding the battery in place which must be pushed back in order to free the battery.
      • Once the battery is removed push the SD card and this will activate a spring ejecting the card from the camera.
      询问修复机器人
      添加评论
    3. Canon PowerShot A2500 Flash Component Replacement: 步骤 3 中的图像 1,3 Canon PowerShot A2500 Flash Component Replacement: 步骤 3 中的图像 2,3 Canon PowerShot A2500 Flash Component Replacement: 步骤 3 中的图像 3,3
      • Remove the 6 Phillips #00 exterior screws from the camera. Two are located on the bottom and two are located on either side as shown. Notice that one of the screws is under the AV Out Digital flap on the side. All exterior screws should be 2.4mm in length
      询问修复机器人
      添加评论
    4. Canon PowerShot A2500 Flash Component Replacement: 步骤 4 中的图像 1,3 Canon PowerShot A2500 Flash Component Replacement: 步骤 4 中的图像 2,3 Canon PowerShot A2500 Flash Component Replacement: 步骤 4 中的图像 3,3
      • Pry apart the camera casing using the plastic opening tool tool provided. Once the casing has begun to separate pull the two sides apart with your hands.
      • Be careful not to bend the plastic casing to much, as it will crack.
      询问修复机器人
      添加评论
    1. Canon PowerShot A2500 Flash Component Replacement, Flash Component: 步骤 5 中的图像 1,1
      • Lift LCD Display using the plastic opening tool to access the screws.
      询问修复机器人
      添加评论
    2. Canon PowerShot A2500 Flash Component Replacement: 步骤 6 中的图像 1,1
      • Remove top left phillips #00 screw under LCD display
      • The screw should be 3.6mm long and the face of the screw should have a 2.4mm diameter
      询问修复机器人
      添加评论
    3. Canon PowerShot A2500 Flash Component Replacement: 步骤 7 中的图像 1,2 Canon PowerShot A2500 Flash Component Replacement: 步骤 7 中的图像 2,2
      • Once the screw is removed lift small brown tab and carefully remove the ribbon tape connecting the flash component to the camera
      • Now the flash component is completely separated from the computer and ready to be replaced or repaired
      • Be sure to have the battery removed before disconnecting this tab. This will ensure that there is no possible charge remaining in the capacitor.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 3-4, Duarte Spring 2015 UMass Dartmouth, Team 3-4, Duarte Spring 2015 的会员
UMASSD-DUARTE-S15S3G4
4 名成员
创作了12篇指南
1指南评论
Great tutorial, but I am left with one problem - where can I buy a flash component? Just can’t seem to find any on the internet.
Jonathan, UK
Jonathan Mitchell - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 1,062
