跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot A2300 Flash Assembly Replacement
你所需要的
    1. Canon PowerShot A2300 Flash Assembly Replacement, Front Cover: 步骤 1 中的图像 1,1
      • Open the A/V Out Digital port cover on the function button side to reveal a screw.
      询问修复机器人
      添加评论
    2. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 2 中的图像 1,3 Canon PowerShot A2300 Flash Assembly Replacement: 步骤 2 中的图像 2,3 Canon PowerShot A2300 Flash Assembly Replacement: 步骤 2 中的图像 3,3
      • Remove all 6 screws(2.70 mm), 2 on each side and 2 on the bottom.
      • Screws are small and very easily lost.
      询问修复机器人
      添加评论
    3. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 3 中的图像 1,2 Canon PowerShot A2300 Flash Assembly Replacement: 步骤 3 中的图像 2,2
      • Open the card/battery latch by sliding the cover away from the camera in the direction indicated by the arrow.
      • Doing this gives a spot to grip on the bottom of the front cover. This will make it easier to handle when removing.
      询问修复机器人
      添加评论
    4. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 4 中的图像 1,1
      • Gently lift the bottom of the front cover to roughly a 30 degree angle.
      询问修复机器人
      添加评论
    5. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 5 中的图像 1,1
      • Pull the top of the front cover away from the camera by gripping the top of the front cover by the corners where the cover is still attached to the body.
      询问修复机器人
      添加评论
    1. Canon PowerShot A2300 Flash Assembly Replacement, Back Cover: 步骤 6 中的图像 1,1
      • Hold the camera in your hands with both thumbs on the screen with the screen faced up.
      • Keep close to the table top in case the camera falls out of your hands.
      询问修复机器人
      添加评论
    2. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 7 中的图像 1,1
      • Pull the the bottom left corner of the cover up about an inch to the point shown in the picture.
      • Do not completely remove the back cover by pulling on the side as shown. The cover is still attached on the top of the camera.
      询问修复机器人
      添加评论
    3. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 8 中的图像 1,1
      • Pry the top off by sliding the spudger under the On/Off button.
      询问修复机器人
      添加评论
    4. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 9 中的图像 1,1
      • Slide the cover to the right and off the camera.
      • Gently pry using the spudger on the right side if necessary.
      • The A/V OUT DIGITAL cover will sometimes become loose and disconnect from the cover
      询问修复机器人
      添加评论
    1. Canon PowerShot A2300 Flash Assembly Replacement, Flash Assembly: 步骤 10 中的图像 1,1
      • Raise the screen by wedging the spudger between the bottom of the screen and the mount hole.
      询问修复机器人
      添加评论
    2. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 11 中的图像 1,1
      • Remove the metal sheet that is under the screen.
      询问修复机器人
      添加评论
    3. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 12 中的图像 1,1
      • Remove the top left screw on the metal sheet that is behind the screen.
      • This screw connects the flash to the metal sheet.
      询问修复机器人
      添加评论
    4. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 13 中的图像 1,1
      在这个步骤中使用的工具:
      • Use one side of the tweezers to raise the orange retaining flap on the zero insertion force (ZIF) connector to a vertical position.
      询问修复机器人
      添加评论
    5. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 14 中的图像 1,1
      • Gently pull the orange ribbon cable out of the ZIF connector using the tweezers.
      询问修复机器人
      添加评论
    6. Canon PowerShot A2300 Flash Assembly Replacement: 步骤 15 中的图像 1,2 Canon PowerShot A2300 Flash Assembly Replacement: 步骤 15 中的图像 2,2
      • Remove the flash by gently rotating slightly back and forth and pulling up.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Baylor, Team 7-14, Williams Spring 2015 Baylor, Team 7-14, Williams Spring 2015 的会员
BU-WILLIAMS-S15S7G14
4 名成员
创作了30篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 68
总计 2,604
