跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot A2200 LCD Screen Replacement
你所需要的
  1. Canon PowerShot A2200 LCD Screen Replacement, Back Cover: 步骤 1 中的图像 1,1
    • First, remove the batteries and memory card.
    • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
    • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
    询问修复机器人
    添加评论
  2. Canon PowerShot A2200 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
    询问修复机器人
    添加评论
  3. Canon PowerShot A2200 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
    询问修复机器人
    添加评论
  4. Canon PowerShot A2200 LCD Screen Replacement: 步骤 4 中的图像 1,3 Canon PowerShot A2200 LCD Screen Replacement: 步骤 4 中的图像 2,3 Canon PowerShot A2200 LCD Screen Replacement: 步骤 4 中的图像 3,3
    • Begin taking off the back cover with a plastic opening tool.
    • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
    • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
    • Continue taking off the back cover along the left side of the camera as seen in the third picture.
    询问修复机器人
    添加评论
  5. Canon PowerShot A2200 LCD Screen Replacement: 步骤 5 中的图像 1,3 Canon PowerShot A2200 LCD Screen Replacement: 步骤 5 中的图像 2,3 Canon PowerShot A2200 LCD Screen Replacement: 步骤 5 中的图像 3,3
    • Use the plastic opening tool to separate the top section of the back cover from the frame.
    • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
    询问修复机器人
    添加评论
  6. Canon PowerShot A2200 LCD Screen Replacement, Button Assembly: 步骤 6 中的图像 1,2 Canon PowerShot A2200 LCD Screen Replacement, Button Assembly: 步骤 6 中的图像 2,2
    • Remove the internal 4.4mm screw with a Phillips 00 screwdriver.
    • Make sure you're removing the screw circled in red, not the screw crossed out in orange.
    添加评论
  7. Canon PowerShot A2200 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Gently lift of the buttons for replacement. They should come off without excessive force.
    • If the buttons do not lift off easily, you may have unscrewed the wrong screw. Revert to previous step.
    添加评论
  8. Canon PowerShot A2200 LCD Screen Replacement, LCD Screen: 步骤 8 中的图像 1,1
    • Lift up the electrical ribbon shown to access the next screw.
    • Remove the 3.9 mm screw with a Phillips #00 screwdriver.
    询问修复机器人
    添加评论
  9. Canon PowerShot A2200 LCD Screen Replacement: 步骤 9 中的图像 1,1
    询问修复机器人
    添加评论
  10. Canon PowerShot A2200 LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Remove the two 3.9 mm screws shown with a Phillips #00 screwdriver.
    询问修复机器人
    添加评论
  11. Canon PowerShot A2200 LCD Screen Replacement: 步骤 11 中的图像 1,2 Canon PowerShot A2200 LCD Screen Replacement: 步骤 11 中的图像 2,2
    • There is an electrical flap that holds the LCD ribbon down. Note the flap in is closed position.
    • Lift up the flap with a plastic opening tool.
    询问修复机器人
    添加评论
  12. Canon PowerShot A2200 LCD Screen Replacement: 步骤 12 中的图像 1,1
    • Holding the outer frame of the LCD screen, gently lift the LCD screen for replacement.
    询问修复机器人
    添加评论
  13. Canon PowerShot A2200 LCD Screen Replacement: 步骤 13 中的图像 1,3 Canon PowerShot A2200 LCD Screen Replacement: 步骤 13 中的图像 2,3 Canon PowerShot A2200 LCD Screen Replacement: 步骤 13 中的图像 3,3
    • This step is only for replacement. If you are not replacing the LCD screen, skip this step.
    • Locate ribbon flap, enclosed in red. (picture 1)
    • Using a plastic opening tool, lift up the ribbon flap to allow insertion of the LCD ribbon. (picture 2)
    • Place the LCD screen on the camera and align the ribbon underneath the open ribbon flap. Close the ribbon flap onto the ribbon. (picture 3)
    询问修复机器人
    添加评论
结论
To reassemble your device, follow these instructions in reverse order, starting with the last guide step.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Benjamin Gee
于03/31/15注册
983 声望
创作了5篇指南
团队
Baylor, Team 4-5, Williams Spring 2015 Baylor, Team 4-5, Williams Spring 2015 的会员
BU-WILLIAMS-S15S4G5
4 名成员
创作了13篇指南
2指南评论
Step 11, “lift up the flap” did the trick - thanks !!
Mine got wet with seawater, I cleaned the electronics wih alcohol and it works again.
Chris W - 回复 分享
My problem is after taking a photo and seeing the preview instead of going back to “live” display for the next photo the screen goes black but the camera settings still show.  Would changing the screen solve this problem?
Ken Short - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 72
总计 2,334
