跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot A2200 Button Assembly Replacement
你所需要的
    1. Canon PowerShot A2200 Button Assembly Replacement, Back Cover: 步骤 1 中的图像 1,1
      • First, remove the batteries and memory card.
      • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
      • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    2. Canon PowerShot A2200 Button Assembly Replacement: 步骤 2 中的图像 1,1
      • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    3. Canon PowerShot A2200 Button Assembly Replacement: 步骤 3 中的图像 1,1
      • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    4. Canon PowerShot A2200 Button Assembly Replacement: 步骤 4 中的图像 1,3 Canon PowerShot A2200 Button Assembly Replacement: 步骤 4 中的图像 2,3 Canon PowerShot A2200 Button Assembly Replacement: 步骤 4 中的图像 3,3
      • Begin taking off the back cover with a plastic opening tool.
      • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
      • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
      • Continue taking off the back cover along the left side of the camera as seen in the third picture.
      询问修复机器人
      添加评论
    5. Canon PowerShot A2200 Button Assembly Replacement: 步骤 5 中的图像 1,3 Canon PowerShot A2200 Button Assembly Replacement: 步骤 5 中的图像 2,3 Canon PowerShot A2200 Button Assembly Replacement: 步骤 5 中的图像 3,3
      • Use the plastic opening tool to separate the top section of the back cover from the frame.
      • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
      询问修复机器人
      添加评论
    1. Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: 步骤 6 中的图像 1,2 Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: 步骤 6 中的图像 2,2
      • Remove the internal 4.4mm screw with a Phillips 00 screwdriver.
      • Make sure you're removing the screw circled in red, not the screw crossed out in orange.
      添加评论
    2. Canon PowerShot A2200 Button Assembly Replacement: 步骤 7 中的图像 1,1
      • Gently lift of the buttons for replacement. They should come off without excessive force.
      • If the buttons do not lift off easily, you may have unscrewed the wrong screw. Revert to previous step.
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Benjamin Gee
于03/31/15注册
983 声望
创作了5篇指南
团队
Baylor, Team 4-5, Williams Spring 2015 Baylor, Team 4-5, Williams Spring 2015 的会员
BU-WILLIAMS-S15S4G5
4 名成员
创作了13篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 29
总计 1,100
