跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot A200 LCD Display Replacement
你所需要的
    1. Canon PowerShot A200 LCD Display Replacement, Canon PowerShot A200: 步骤 1 中的图像 1,1
      • Use a Phillips #00 screwdriver to remove the two screws located at the bottom of the camera.
      询问修复机器人
      添加评论
    2. Canon PowerShot A200 LCD Display Replacement: 步骤 2 中的图像 1,2 Canon PowerShot A200 LCD Display Replacement: 步骤 2 中的图像 2,2
      • Locate the screw and the rubber covering on the left side of the camera. Slide the rubber covering to expose a second screw.
      • Remove the two screws with the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    3. Canon PowerShot A200 LCD Display Replacement: 步骤 3 中的图像 1,2 Canon PowerShot A200 LCD Display Replacement: 步骤 3 中的图像 2,2
      • Open the battery compartment on the right side of the camera by pushing slightly in the direction of the arrow.
      • Be sure to remove the memory card.
      • Remove the two screws by the memory card slot using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    4. Canon PowerShot A200 LCD Display Replacement: 步骤 4 中的图像 1,2 Canon PowerShot A200 LCD Display Replacement: 步骤 4 中的图像 2,2
      • Pull the grey tab towards the back of the camera. Lift the black cover to expose the battery slots.
      • Remove the two visible screws with the Phillips #00 screwdriver.
      • During reassembly, the holes for these screws must align properly with the interior of the camera body. Then the black battery cover must lie flat and be held in place by the grey tab.
      询问修复机器人
      添加评论
    5. Canon PowerShot A200 LCD Display Replacement: 步骤 5 中的图像 1,2 Canon PowerShot A200 LCD Display Replacement: 步骤 5 中的图像 2,2
      • Remove the screen battery located to the left of the screen.
      • Set the screen battery aside for reassembly
      询问修复机器人
      添加评论
    6. Canon PowerShot A200 LCD Display Replacement: 步骤 6 中的图像 1,2 Canon PowerShot A200 LCD Display Replacement: 步骤 6 中的图像 2,2
      • Gently pull the camera apart from the top.
      • Be careful. The two halves are still attached by two short ribbons at the bottom of the camera.
      询问修复机器人
      添加评论
    7. Canon PowerShot A200 LCD Display Replacement: 步骤 7 中的图像 1,2 Canon PowerShot A200 LCD Display Replacement: 步骤 7 中的图像 2,2
      在这个步骤中使用的工具:
      • Locate the black tabs on either side of the white ribbon.
      • Use the metal tweezers to gently move these tabs to the outside edges of the ribbon.
      • Gently pull the white ribbon out from its connection.
      询问修复机器人
      添加评论
    8. Canon PowerShot A200 LCD Display Replacement: 步骤 8 中的图像 1,3 Canon PowerShot A200 LCD Display Replacement: 步骤 8 中的图像 2,3 Canon PowerShot A200 LCD Display Replacement: 步骤 8 中的图像 3,3
      • Locate the black tabs on either side of the orange ribbon.
      • Gently pull the orange ribbon out of its connection.
      • Your camera will now be in two separate pieces.
      询问修复机器人
      添加评论
    1. Canon PowerShot A200 LCD Display Replacement, LCD Display: 步骤 9 中的图像 1,1
      • Use a Phillips head screwdriver to remove the four screws from the corners of the LCD.
      询问修复机器人
      添加评论
    2. Canon PowerShot A200 LCD Display Replacement: 步骤 10 中的图像 1,1
      • Use the iFixit plastic opening tool to lift the LCD away from the back case.
      • The LCD will still be attached to the back of the camera case by an orange strip.
      询问修复机器人
      添加评论
    3. Canon PowerShot A200 LCD Display Replacement: 步骤 11 中的图像 1,1
      • Use a soldering iron to remove the LCD from the orange cable connected to the back of the camera.
      • Use the soldering iron to attach your new LCD in place.
      • Caution: When soldering, allow enough slack in the orange cable, so the LCD will lie flat. The white bar will lie parallel with the electronic components embedded in the motherboard.
      询问修复机器人
      添加评论
结论
Follow the instructions in the prerequisite guide Disassembling the Canon PowerShot A200 Case.
Once completed, proceed with installing a new LCD Display.
取消:我没有完成这个指南。
Jeff Barich
于01/28/11注册
101 声望
撰写一个指南
团队
Cal Poly, Team 7-37, Regan Winter 2011 Cal Poly, Team 7-37, Regan Winter 2011 的会员
CPSU-REGAN-W11S7G37
4 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 34
总计 1,421
