跳转到主内容
加入维修社区 - 创建账户
Canon PIXMA iP3600 AC Adapter Replacement
    1. Canon PIXMA iP3600 AC Adapter Replacement, AC Adapter: 步骤 1 中的图像 1,2 Canon PIXMA iP3600 AC Adapter Replacement, AC Adapter: 步骤 1 中的图像 2,2
      • It is very important to disconnect your printer from the outlet before attempting replacement. This ensures that there is no power reaching the AC adapter.
      • Remove power cord by disconnecting it from the AC Adapter.
      询问修复机器人
      添加评论
    2. Canon PIXMA iP3600 AC Adapter Replacement: 步骤 2 中的图像 1,2 Canon PIXMA iP3600 AC Adapter Replacement: 步骤 2 中的图像 2,2
      • Pinch upper and lower prongs, moving them away from the AC adapter.
      询问修复机器人
      添加评论
    3. Canon PIXMA iP3600 AC Adapter Replacement: 步骤 3 中的图像 1,2 Canon PIXMA iP3600 AC Adapter Replacement: 步骤 3 中的图像 2,2
      • The AC adapter will now be loose, and able to come away from the printer.
      • Grasp the AC adapter and pull it toward you to remove it.
      询问修复机器人
      添加评论
    4. Canon PIXMA iP3600 AC Adapter Replacement: 步骤 4 中的图像 1,1
      • Rotate the AC adapter toward you so that the blue cord, with white connector head, is facing you.
      询问修复机器人
      添加评论
    5. Canon PIXMA iP3600 AC Adapter Replacement: 步骤 5 中的图像 1,3 Canon PIXMA iP3600 AC Adapter Replacement: 步骤 5 中的图像 2,3 Canon PIXMA iP3600 AC Adapter Replacement: 步骤 5 中的图像 3,3
      • Grasp the white connector head that is attached to the end of the blue cord.
      • Disconnect the white connector head by gently pulling it away from the AC adapter.
      • You have successfully removed the AC adapter.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
Caitlyn
于10/07/14注册
1,223 声望
创作了4篇指南
团队
USF Tampa, Team 1-3, Leahy Fall 2014 USF Tampa, Team 1-3, Leahy Fall 2014 的会员
USFT-LEAHY-F14S1G3
3 名成员
创作了28篇指南
3指南评论
Does anybody know the pin-out for these power supplies?
James Rudee - 回复 分享
WHERE CAN I BUY AC ADAPTER PIXMA GM 5220 PRINTER ? PLAESE !! my cell 678 899 1187, 770368 0409 w
vincent lieu - 回复 分享
Well I’ve just taken the AC Adapter out - I’ll let you know if a the replacement works once I’ve purchased it - Which I am hesitant to buy in case that’s not the problem.
The printer is barely 2 years old and barely used, I shouldn’t be experiencing this problem of the printer not turning on.
Canon you need to get your act together if you would like to stay in business, I’m seeing a lot of comments on this problem over a range of different printer models - Mine is a Pixma iX6860.
rezidraft - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 64
总计 5,978
