跳转到主内容
加入维修社区 - 创建账户
Canon PIXMA MP620B USB Reader Replacement
你所需要的
    1. Canon PIXMA MP620B USB Reader Replacement, Pop off right blue side panel: 步骤 1 中的图像 1,2 Canon PIXMA MP620B USB Reader Replacement, Pop off right blue side panel: 步骤 1 中的图像 2,2
      • Locate the tabs on the top of the panel that hook down and into the black side panel.
      • Insert the Spudger in-between the black panel and the blue panel as shown and pull the two pieces apart.
      • You will hear some snapping. Don't panic: this is just the hooks un-clipping.
      询问修复机器人
      添加评论
    2. Canon PIXMA MP620B USB Reader Replacement, Loosen the back panel: 步骤 2 中的图像 1,1
      • Remove the two screws from the back right black panel using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    3. Canon PIXMA MP620B USB Reader Replacement, Pull off black side panel: 步骤 3 中的图像 1,2 Canon PIXMA MP620B USB Reader Replacement, Pull off black side panel: 步骤 3 中的图像 2,2
      • There is a tab you will have to push down to remove the part.
      • Once the tab is released, gently lift the cover away from the rest of the device to disengage the clips.
      • You will hear some snapping. Don't panic: this is just the clips un-clipping.
      询问修复机器人
      添加评论
    4. Canon PIXMA MP620B USB Reader Replacement, Take off the black side panel: 步骤 4 中的图像 1,1
      • After unclipping all the hooks, pull off the black side panel to reveal the inner circuit boards.
      询问修复机器人
      添加评论
    5. Canon PIXMA MP620B USB Reader Replacement, Unscrew 2 screws from USB chip: 步骤 5 中的图像 1,1
      • Remove the two screws from the USB reader using the Phillips #00 screwdriver.
      • The angle for removing the screws can be somewhat challenging, try not to get too frustrated.
      询问修复机器人
      添加评论
    6. Canon PIXMA MP620B USB Reader Replacement, Pull out USB chip and disconnect white wire: 步骤 6 中的图像 1,1
      • Disconnect the large white ribbon cable that leads to the USB reader. As you are pulling out the USB reader, carefully detach the ribbon.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
Cal Poly, Team 6-21, Maness Fall 2014 Cal Poly, Team 6-21, Maness Fall 2014 的会员
CPSU-MANESS-F14S6G21
4 名成员
创作了35篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 32
总计 1,211
