跳转到主内容
加入维修社区 - 创建账户
Canon EOS Rebel XTi Shutter Button Replacement
你所需要的
    1. Canon EOS Rebel XTi Shutter Button Replacement, Battery: 步骤 1 中的图像 1,1
      • Place the camera upside down, and position it to where the back of the camera is visible.
      询问修复机器人
      添加评论
    2. Canon EOS Rebel XTi Shutter Button Replacement: 步骤 2 中的图像 1,1
      • Pull the orange tab to the right to release the primary battery.
      询问修复机器人
      添加评论
    3. Canon EOS Rebel XTi Shutter Button Replacement: 步骤 3 中的图像 1,1
      • To remove the secondary battery, reposition the camera to where the display screen is facing upwards.
      • Place your finger inside the empty battery compartment and pull away from the camera on the ridged battery tab.
      添加评论
    1. Canon EOS Rebel XTi Shutter Button Replacement, Memory Card: 步骤 4 中的图像 1,1
      • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
      询问修复机器人
      添加评论
    2. Canon EOS Rebel XTi Shutter Button Replacement: 步骤 5 中的图像 1,1
      • Slide the memory card door in the direction of the arrow engraved on the camera.
      • Once the door has slid open to its full position, lift up on the door.
      询问修复机器人
      添加评论
    3. Canon EOS Rebel XTi Shutter Button Replacement: 步骤 6 中的图像 1,1
      • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
      • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
      询问修复机器人
      添加评论
    1. Canon EOS Rebel XTi Shutter Button Replacement, Back Cover: 步骤 7 中的图像 1,1
      • Remove the three black M3x4mm JIS #000 screws on the bottom of the camera.
      询问修复机器人
      添加评论
    2. Canon EOS Rebel XTi Shutter Button Replacement: 步骤 8 中的图像 1,2 Canon EOS Rebel XTi Shutter Button Replacement: 步骤 8 中的图像 2,2
      • Remove the two black M3x6mm JIS #000 screws from the right side of the camera.
      询问修复机器人
      添加评论
    3. Canon EOS Rebel XTi Shutter Button Replacement: 步骤 9 中的图像 1,1
      • Remove the two M3x5mm JIS #000 screws on the side of the camera opposite to the hand grip.
      询问修复机器人
      添加评论
    4. Canon EOS Rebel XTi Shutter Button Replacement: 步骤 10 中的图像 1,1
      • Remove the following screws located in the memory card slot:
      • Two M3x2mm JIS #000 screws
      询问修复机器人
      添加评论
    5. Canon EOS Rebel XTi Shutter Button Replacement: 步骤 11 中的图像 1,1
      • Gently pry off the back casing.
      • Before completely removing the back casing, be sure to disconnect the single ribbon cable running from the motherboard to the LCD display.
      • Use a spudger to lift the tab on the ribbon cable's ZIF connector.
      • Gently pull the ribbon cable out of the connector.
      添加评论
    1. Canon EOS Rebel XTi Shutter Button Replacement, Front Cover: 步骤 12 中的图像 1,1
      • Remove the following screws from the bottom of the camera:
      • Two M3x4.5mm JIS #000 screws
      • One M3x3mm JIS #000 screw
      询问修复机器人
      添加评论
    2. Canon EOS Rebel XTi Shutter Button Replacement: 步骤 13 中的图像 1,1
      • Remove the following screws from the front of the camera:
      • Two M3x6mm JIS #000 screws
      询问修复机器人
      添加评论
    3. Canon EOS Rebel XTi Shutter Button Replacement: 步骤 14 中的图像 1,1
      • Gently pry off the front casing.
      • There are no ribbon cables to remove for this portion of the disassembly.
      添加评论
    1. Canon EOS Rebel XTi Shutter Button Replacement, Top Cover: 步骤 15 中的图像 1,3 Canon EOS Rebel XTi Shutter Button Replacement, Top Cover: 步骤 15 中的图像 2,3 Canon EOS Rebel XTi Shutter Button Replacement, Top Cover: 步骤 15 中的图像 3,3
      • Remove the following screws from around the viewfinder:
      • One 10mm JIS #00 diopter screw
      • Two M3x6mm JIS #00 screws
      询问修复机器人
      添加评论
    2. Canon EOS Rebel XTi Shutter Button Replacement: 步骤 16 中的图像 1,3 Canon EOS Rebel XTi Shutter Button Replacement: 步骤 16 中的图像 2,3 Canon EOS Rebel XTi Shutter Button Replacement: 步骤 16 中的图像 3,3
      • Remove the following screws on each side of the camera under the strap hooks:
      • One M3x5mm JIS #00 screw
      • One M3x4.5mm JIS #00 screw
      询问修复机器人
      添加评论
    3. Canon EOS Rebel XTi Shutter Button Replacement: 步骤 17 中的图像 1,1
      • Separate the top casing from the electrical components enough to expose the wire harnesses that will need to be disconnected.
      • Ensure to remove the casing gently. There are several wire harnesses connecting the motherboard to components on the casing.
      询问修复机器人
      添加评论
    4. Canon EOS Rebel XTi Shutter Button Replacement: 步骤 18 中的图像 1,1
      • Unplug the yellow connector located on the top of the camera.
      询问修复机器人
      添加评论
    5. Canon EOS Rebel XTi Shutter Button Replacement: 步骤 19 中的图像 1,1
      • Disconnect the red connector located by the USB port.
      询问修复机器人
      添加评论
    1. Canon EOS Rebel XTi Shutter Button Replacement, Shutter Button: 步骤 20 中的图像 1,1
      • Use a JIS #00 screwdriver to remove the two silver 4 mm screws from underneath the shutter button.
      询问修复机器人
      添加评论
    2. Canon EOS Rebel XTi Shutter Button Replacement: 步骤 21 中的图像 1,3 Canon EOS Rebel XTi Shutter Button Replacement: 步骤 21 中的图像 2,3 Canon EOS Rebel XTi Shutter Button Replacement: 步骤 21 中的图像 3,3
      • Use a JIS #00 screwdriver to remove the 3mm screws from the plate under the shutter button.
      • Place the components off to the side without removing any ribbons.
      • Be careful as ribbon cables are fragile and may rip easily.
      询问修复机器人
      添加评论
    3. Canon EOS Rebel XTi Shutter Button Replacement: 步骤 22 中的图像 1,1
      • Use a 1.5mm flat head bit to remove the c-clip from underneath the snapshot button by pushing against the open side of the pin.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Luis Calle
于08/30/15注册
431 声望
创作了3篇指南
团队
USF Tampa, Team 8-6, Eyestone Fall 2015 USF Tampa, Team 8-6, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G6
3 名成员
创作了45篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 51
总计 1,674
