跳转到主内容
加入维修社区 - 创建账户
Canon EOS Rebel T5 Image Sensor Replacement
你所需要的
  1. Canon EOS Rebel T5 Image Sensor Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
    询问修复机器人
    添加评论
  2. Canon EOS Rebel T5 Image Sensor Replacement: 步骤 2 中的图像 1,1
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
    询问修复机器人
    添加评论
  3. Canon EOS Rebel T5 Image Sensor Replacement, Back Cover: 步骤 3 中的图像 1,1
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm JIS #000 screw above the rubber USB port cover.
    添加评论
  4. Canon EOS Rebel T5 Image Sensor Replacement: 步骤 4 中的图像 1,1
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
    询问修复机器人
    添加评论
  5. Canon EOS Rebel T5 Image Sensor Replacement: 步骤 5 中的图像 1,1
    • Turn your camera so that the bottom is facing you.
    • Remove the four 5mm JIS #000 screws.
    添加评论
  6. Canon EOS Rebel T5 Image Sensor Replacement: 步骤 6 中的图像 1,1
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm JIS #000 screws.
    添加评论
  7. Canon EOS Rebel T5 Image Sensor Replacement: 步骤 7 中的图像 1,3 Canon EOS Rebel T5 Image Sensor Replacement: 步骤 7 中的图像 2,3 Canon EOS Rebel T5 Image Sensor Replacement: 步骤 7 中的图像 3,3
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
    添加评论
  8. Canon EOS Rebel T5 Image Sensor Replacement, Motherboard: 步骤 8 中的图像 1,2 Canon EOS Rebel T5 Image Sensor Replacement, Motherboard: 步骤 8 中的图像 2,2
    • Remove all ribbon cables with the plastic spudger.
    • Gently pry up the black plastic tabs to slide out the ribbon cables
    • Take note of this black cable and where it connects to the motherboard. This is a fiber optic cable which is used for the camera flash. It will need to be reconnected after replacing the motherboard.
    • When reconnecting the fiber optic cable, simply push the black cable into the hole in the connector and push it all the way in.
    询问修复机器人
    添加评论
  9. Canon EOS Rebel T5 Image Sensor Replacement: 步骤 9 中的图像 1,1
    • Turn your camera so that the top is facing you.
    • Remove the two black 5 mm JIS #000 screws.
    询问修复机器人
    添加评论
  10. Canon EOS Rebel T5 Image Sensor Replacement: 步骤 10 中的图像 1,3 Canon EOS Rebel T5 Image Sensor Replacement: 步骤 10 中的图像 2,3 Canon EOS Rebel T5 Image Sensor Replacement: 步骤 10 中的图像 3,3
    • Turn the grip side toward you.
    • Remove the rubber grip, using the plastic spudger.
    询问修复机器人
    添加评论
  11. Canon EOS Rebel T5 Image Sensor Replacement: 步骤 11 中的图像 1,1
    • Remove the black 5 mm JIS #000 screw, located under the grip.
    • Remove the three 3.5mm JIS #000 screws on the bottom of the case.
    添加评论
  12. Canon EOS Rebel T5 Image Sensor Replacement: 步骤 12 中的图像 1,1
    • Remove the top panel of the device.
    询问修复机器人
    添加评论
  13. Canon EOS Rebel T5 Image Sensor Replacement: 步骤 13 中的图像 1,2 Canon EOS Rebel T5 Image Sensor Replacement: 步骤 13 中的图像 2,2
    • Remove the front panel of the camera.
    询问修复机器人
    添加评论
  14. Canon EOS Rebel T5 Image Sensor Replacement: 步骤 14 中的图像 1,3 Canon EOS Rebel T5 Image Sensor Replacement: 步骤 14 中的图像 2,3 Canon EOS Rebel T5 Image Sensor Replacement: 步骤 14 中的图像 3,3
    • Remove the five silver 5mm JIS #000 screws.
    • The motherboard can now be removed.
    添加评论
  15. Canon EOS Rebel T5 Image Sensor Replacement, Image Sensor: 步骤 15 中的图像 1,2 Canon EOS Rebel T5 Image Sensor Replacement, Image Sensor: 步骤 15 中的图像 2,2
    • The screws holding the image sensor in place is set to a very specific height. Unless they are returned to the exact same height after replacement, the camera will no longer be in focus unless the focus is recalibrated.
    • Remove the three silver 3mm JIS #000 screws from the image sensor holder.
    • Remove the image sensor holder.
    询问修复机器人
    添加评论
  16. Canon EOS Rebel T5 Image Sensor Replacement: 步骤 16 中的图像 1,3 Canon EOS Rebel T5 Image Sensor Replacement: 步骤 16 中的图像 2,3 Canon EOS Rebel T5 Image Sensor Replacement: 步骤 16 中的图像 3,3
    • Remove the three remaining silver 3mm JIS #000 screws from the image sensor.
    • Be careful not lose the springs underneath the screws on the image sensor
    • Using your fingers, lift the image sensor from the device.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
13等其他人完成本指南。
Tyler Brown
于09/22/14注册
921 声望
创作了2篇指南
团队
USF Tampa, Team 16-4, Wollert Fall 2015 USF Tampa, Team 16-4, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G4
4 名成员
创作了18篇指南
3指南评论
Thanks for the post. I was able to take this apart without damage to any of the camera parts. I am wondering if you happen to have the data sheet for the camera sensor, 704f? I cannot seem to find one.
Dawn - 回复 分享
Hi. I do not see where it explains the calibration of the Sensor. Could you give me some reference about that?
ivanram - 回复 分享
I reassembled on the camera no longer powers on, i checked disassembled again, checked for loose wires, ribbons, everything looks perfect and still it’s completely dead.
Edward Perkins - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 23
过去 30 天: 86
总计 9,428
