跳转到主内容
加入维修社区 - 创建账户
Canon EOS A2 Control Dial Replacement
你所需要的
  1. Canon EOS A2 Control Dial Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
    询问修复机器人
    添加评论
  2. Canon EOS A2 Control Dial Replacement: 步骤 2 中的图像 1,1
    • Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
    添加评论
  3. Canon EOS A2 Control Dial Replacement: 步骤 3 中的图像 1,1
    • Remove the battery from inside the battery housing and set the cover aside.
    询问修复机器人
    添加评论
  4. Canon EOS A2 Control Dial Replacement, Front Cover: 步骤 4 中的图像 1,1
    • Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
    询问修复机器人
    添加评论
  5. Canon EOS A2 Control Dial Replacement: 步骤 5 中的图像 1,1
    • Remove the 6.4mm screw from the inside of the flash bezel.
    • If the flash is locked down, insert the battery, then with the help of a pencil turn the rotary (CW or CCW) switch until the "125" is displayed in the LCD. Press the Flash symbol button. You should hear the latch from the flash, then you can manually lift the flash. If OK, then remove the battery from the camera
    添加评论
  6. Canon EOS A2 Control Dial Replacement: 步骤 6 中的图像 1,1
    • Flip the camera upside down and remove the 5.4mm screw below the lens bezel on the front of the camera.
    询问修复机器人
    添加评论
  7. Canon EOS A2 Control Dial Replacement: 步骤 7 中的图像 1,1
    • Remove the 5.6mm screws behind the battery cover.
    询问修复机器人
    添加评论
  8. Canon EOS A2 Control Dial Replacement: 步骤 8 中的图像 1,1
    • Remove two 6.4mm screws on the latch mechanism on the right side of the camera.
    询问修复机器人
    添加评论
  9. Canon EOS A2 Control Dial Replacement: 步骤 9 中的图像 1,1
    • Remove the 6.4mm screw on the top of the inside edge of the battery hole.
    询问修复机器人
    添加评论
  10. Canon EOS A2 Control Dial Replacement: 步骤 10 中的图像 1,2 Canon EOS A2 Control Dial Replacement: 步骤 10 中的图像 2,2
    • Starting at the flash, carefully pull the front cover away from the camera.
    询问修复机器人
    添加评论
  11. Canon EOS A2 Control Dial Replacement, Top Cover: 步骤 11 中的图像 1,1
    • Remove the 4.3mm screw below the camera strap ring.
    询问修复机器人
    添加评论
  12. Canon EOS A2 Control Dial Replacement: 步骤 12 中的图像 1,1
    • Remove two 4.8mm screws located on both sides of the eyepiece.
    询问修复机器人
    添加评论
  13. Canon EOS A2 Control Dial Replacement: 步骤 13 中的图像 1,1
    • Pull the top cover up slowly.
    • A ribbon cable is attached to the bottom of the top cover and the camera. Pull up very carefully to avoid damaging this.
    询问修复机器人
    添加评论
  14. Canon EOS A2 Control Dial Replacement: 步骤 14 中的图像 1,1
    • Once you have revealed the ribbon cable, gently let the top cover hang off the front of the camera. Use the plastic opening tool to gently pull the white tabs on the ribbon cable, releasing the ribbon cable.
    • If you pull the white tabs all the way out, just insert them back in to avoid losing them.
    询问修复机器人
    添加评论
  15. Canon EOS A2 Control Dial Replacement, Control Dial: 步骤 15 中的图像 1,3 Canon EOS A2 Control Dial Replacement, Control Dial: 步骤 15 中的图像 2,3 Canon EOS A2 Control Dial Replacement, Control Dial: 步骤 15 中的图像 3,3
    • Remove the 3mm screw from the back of the control dial while holding the front of the control dial.
    • Be ready to catch the control dial, button, and spring that will fall out with your hand.
    询问修复机器人
    添加评论
  16. Canon EOS A2 Control Dial Replacement: 步骤 16 中的图像 1,1
    • On the bottom side of the top bezel, remove the ring, detent ball and spring. Your control dial is now ready to be replaced with a working unit.
    添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
Jessica
于04/20/11注册
52 声望
撰写一个指南
团队
Cal Poly, Team 8-9, Regan Spring 2011 Cal Poly, Team 8-9, Regan Spring 2011 的会员
CPSU-REGAN-S11S8G9
4 名成员
创作了13篇指南
9指南评论
Is it safe to do this procedure while a film is inside the camera?
Giovanni Murru - 回复 分享
I was wondering if anyone could help me were I could possibly get the new parts?
I've looked around but found nothing relevant so far.
Thanks in advance,
Agoston Horanyi
horanyiagoston - 回复 分享
Did you find the parts ? If no go to eBay.
as exemple : https://www.ebay.com/itm/Canon-EOS-A2E-R...
gilberto - 回复 分享
I'm wondering if there is someone who can fix the mode selector for a reasonable price
zekesrule - 回复 分享
How can I open the flash to get to the screw that needs to be removed in order to fix the rotary dial when the rotary dial is moving freely and the camera does not turn on?
Lucas - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 24
过去 30 天: 120
总计 10,817
