跳转到主内容
加入维修社区 - 创建账户
Canon EOS 30 LCD Screen Replacement
你所需要的
  1. Canon EOS 30 LCD Screen Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
    询问修复机器人
    添加评论
  2. Canon EOS 30 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
    询问修复机器人
    添加评论
  3. Canon EOS 30 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the 4.8 mm black screw on the left side of the camera.
    询问修复机器人
    添加评论
  4. Canon EOS 30 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the front panel by lifting it away from the camera's body.
    添加评论
  5. Canon EOS 30 LCD Screen Replacement, Top Panel: 步骤 5 中的图像 1,1
    • Slide the outer eyepiece upward to remove it.
    询问修复机器人
    添加评论
  6. Canon EOS 30 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the two 4.75 mm black screws located on the top of the camera.
    询问修复机器人
    添加评论
  7. Canon EOS 30 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
    询问修复机器人
    添加评论
  8. Canon EOS 30 LCD Screen Replacement: 步骤 8 中的图像 1,2 Canon EOS 30 LCD Screen Replacement: 步骤 8 中的图像 2,2
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
    询问修复机器人
    添加评论
  9. Canon EOS 30 LCD Screen Replacement, LCD Screen: 步骤 9 中的图像 1,1
    • To unclip gold connector push the edge up and away from the lcd screen. A plastic opening tool is recommended.
    • The gold connector can fall into the camera, but it will remain attached and can be pulled back up.
    询问修复机器人
    添加评论
  10. Canon EOS 30 LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Lift LCD screen out of mount.
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
Cal Poly, Team 8-8, Regan Spring 2011 Cal Poly, Team 8-8, Regan Spring 2011 的会员
CPSU-REGAN-S11S8G8
5 名成员
创作了22篇指南
2指南评论
Thank's , your tutorial nice ... gracias
fajar - 回复 分享
Where do you find replacement lcd screen if the one on the camera is cracked?
Jasmine - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 58
总计 6,114
