跳转到主内容
加入维修社区 - 创建账户
Canon A35F Battery Replacement
你所需要的
    1. Canon A35F Battery Replacement, Battery: 步骤 1 中的图像 1,1
      • Flip the Canon A35F on its top so that the bottom of the camera is facing up.
      • Spot the two windows on the bottom of the camera (each window has the word "OPEN" written, and an arrow, both pointing the same direction).
      • Use your fingernail (or a iFixit opening tool), and push in the direction of the arrow to open the left compartment.
      询问修复机器人
      添加评论
    2. Canon A35F Battery Replacement: 步骤 2 中的图像 1,1
      • Wipe the PX-625 mercury battery with a clean cloth, so that there are no unnecessary fingerprints on the battery.
      • Place the mercury battery in the slot with the yellow ribbon.
      • Make sure to place it in the right side! If it is facing the wrong direction, the shutter will be locked and the meter needle will not move to the battery check zone.
      • Make sure not to leave fingerprints on the battery. It may cause corrosion to the camera's electric contact.
      询问修复机器人
      添加评论
    3. Canon A35F Battery Replacement: 步骤 3 中的图像 1,1
      • Shut the left window close.
      询问修复机器人
      添加评论
    4. Canon A35F Battery Replacement: 步骤 4 中的图像 1,1
      • Use your fingernail (or a iFixit opening tool), and push in the direction of the arrow to open the right compartment.
      询问修复机器人
      添加评论
    5. Canon A35F Battery Replacement: 步骤 5 中的图像 1,1
      • Insert the size AA battery, for the flash, into the compartment (make sure to insert the battery in the right direction).
      询问修复机器人
      添加评论
    6. Canon A35F Battery Replacement: 步骤 6 中的图像 1,1
      • Shut the right window close.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 102
总计 6,430
