跳转到主内容
加入维修社区 - 创建账户
Cable set up
  1. Cable set up, Cable set up: 步骤 1 中的图像 1,1
    • Check that the red RCA plug is connected to the red RCA jack labeled "R" (this indicates the Right speaker).
    • Check that the white RCA plug is connected to the white RCA jack labeled "L" (this indicates the Left speaker).
    • To connect the ground clip, loosen the ground screw and insert the clip. Once clip is secure tighten the screw.
  2. Cable set up: 步骤 2 中的图像 1,1
    • Check the voltage selector switch to make sure its set to the proper voltage depending on your geographic location.
    • Voltage selector should be set to 115 V/60 Hz in the U.S., or 230 V/50 Hz in other countries.
  3. Cable set up: 步骤 3 中的图像 1,1
    • Insert power cable into socket.
终点
Nikolai
于10/12/11注册
281 声望
创作了5篇指南
团队
Cal Poly, Team 17-14, Regan Fall 2011 Cal Poly, Team 17-14, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G14
4 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 16
总计 1,132
