跳转到主内容
加入维修社区 - 创建账户
CASIO CDP-230R Pitch Bend Replacement
你所需要的
    1. CASIO CDP-230R Pitch Bend Replacement, Panels: 步骤 1 中的图像 1,3 CASIO CDP-230R Pitch Bend Replacement, Panels: 步骤 1 中的图像 2,3 CASIO CDP-230R Pitch Bend Replacement, Panels: 步骤 1 中的图像 3,3
      • Flip the keyboard upside down, with the keys on a flat surface.
      • Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
      添加评论
    2. CASIO CDP-230R Pitch Bend Replacement: 步骤 2 中的图像 1,3 CASIO CDP-230R Pitch Bend Replacement: 步骤 2 中的图像 2,3 CASIO CDP-230R Pitch Bend Replacement: 步骤 2 中的图像 3,3
      • Use two hands to grab the side panel from both sides.
      • Pull the panel apart from the device one side at a time.
      • There will be popping sounds when you remove this panel.
      • One side panel will not have an orange & white cable connected to it.
      询问修复机器人
      添加评论
    3. CASIO CDP-230R Pitch Bend Replacement: 步骤 3 中的图像 1,3 CASIO CDP-230R Pitch Bend Replacement: 步骤 3 中的图像 2,3 CASIO CDP-230R Pitch Bend Replacement: 步骤 3 中的图像 3,3
      • Remove the three silver 10mm screws with a J1 screwdriver on the bottom half of the innermost side panel of the device.
      • One side panel will not have an orange & white cable running through.
      询问修复机器人
      添加评论
    4. CASIO CDP-230R Pitch Bend Replacement: 步骤 4 中的图像 1,3 CASIO CDP-230R Pitch Bend Replacement: 步骤 4 中的图像 2,3 CASIO CDP-230R Pitch Bend Replacement: 步骤 4 中的图像 3,3
      • Remove the innermost side panel by pinching the top and bottom of the panel and pulling the panel off with both hands.
      • Repeat steps one through four to remove the other side panel of the keyboard.
      添加评论
    5. CASIO CDP-230R Pitch Bend Replacement: 步骤 5 中的图像 1,3 CASIO CDP-230R Pitch Bend Replacement: 步骤 5 中的图像 2,3 CASIO CDP-230R Pitch Bend Replacement: 步骤 5 中的图像 3,3
      • Remove the two black 30 mm J head screws with a J1 screwdriver to remove the long black bar.
      • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver and the two brackets from the back panel.
      • There will be two screws per bracket.
      询问修复机器人
      添加评论
    6. CASIO CDP-230R Pitch Bend Replacement: 步骤 6 中的图像 1,3 CASIO CDP-230R Pitch Bend Replacement: 步骤 6 中的图像 2,3 CASIO CDP-230R Pitch Bend Replacement: 步骤 6 中的图像 3,3
      • Remove the eight silver 10mm x 1.5mm J head screws with a J1 screwdriver and the square tabs from the back panel.
      • Remove the eight silver 10mm J head screws with a J1 screwdriver underneath the square tabs.
      添加评论
    7. CASIO CDP-230R Pitch Bend Replacement: 步骤 7 中的图像 1,3 CASIO CDP-230R Pitch Bend Replacement: 步骤 7 中的图像 2,3 CASIO CDP-230R Pitch Bend Replacement: 步骤 7 中的图像 3,3
      • Remove the 36 silver 10mm J head screws with a J1 screwdriver from the back panel.
      添加评论
    8. CASIO CDP-230R Pitch Bend Replacement: 步骤 8 中的图像 1,3 CASIO CDP-230R Pitch Bend Replacement: 步骤 8 中的图像 2,3 CASIO CDP-230R Pitch Bend Replacement: 步骤 8 中的图像 3,3
      • Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
      • Having a extra pair of hands will be useful.
      • Grab the center of the front panel with two hands and lift to remove panel.
      • Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
      添加评论
    1. CASIO CDP-230R Pitch Bend Replacement, Pitch Bend: 步骤 9 中的图像 1,3 CASIO CDP-230R Pitch Bend Replacement, Pitch Bend: 步骤 9 中的图像 2,3 CASIO CDP-230R Pitch Bend Replacement, Pitch Bend: 步骤 9 中的图像 3,3
      • Remove the two 8mm x 1.5mm J screws from the inside of the side panel by using a J1 head screwdriver.
      • Slide the pitch bend out of the side panel.
      询问修复机器人
      添加评论
    2. CASIO CDP-230R Pitch Bend Replacement: 步骤 10 中的图像 1,2 CASIO CDP-230R Pitch Bend Replacement: 步骤 10 中的图像 2,2
      • Follow the white and orange cable to the white end that is attached to the button panel
      • Pinch the white end and pull the cord out
      询问修复机器人
      添加评论
    3. CASIO CDP-230R Pitch Bend Replacement: 步骤 11 中的图像 1,1
      • Run the white and orange cable through the innermost side panel and pull out
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Areli Reyes
于10/01/17注册
545 声望
创作了4篇指南
团队
Cal Poly, Team S4-G2, Livingston Fall 2017 Cal Poly, Team S4-G2, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S4G2
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 22
总计 890
