跳转到主内容
加入维修社区 - 创建账户
CASIO CDP-230R Key Replacement
你所需要的
    1. CASIO CDP-230R Key Replacement, Panels: 步骤 1 中的图像 1,3 CASIO CDP-230R Key Replacement, Panels: 步骤 1 中的图像 2,3 CASIO CDP-230R Key Replacement, Panels: 步骤 1 中的图像 3,3
      • Flip the keyboard upside down, with the keys on a flat surface.
      • Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
      添加评论
    2. CASIO CDP-230R Key Replacement: 步骤 2 中的图像 1,3 CASIO CDP-230R Key Replacement: 步骤 2 中的图像 2,3 CASIO CDP-230R Key Replacement: 步骤 2 中的图像 3,3
      • Use two hands to grab the side panel from both sides.
      • Pull the panel apart from the device one side at a time.
      • There will be popping sounds when you remove this panel.
      • One side panel will not have an orange & white cable connected to it.
      询问修复机器人
      添加评论
    3. CASIO CDP-230R Key Replacement: 步骤 3 中的图像 1,3 CASIO CDP-230R Key Replacement: 步骤 3 中的图像 2,3 CASIO CDP-230R Key Replacement: 步骤 3 中的图像 3,3
      • Remove the three silver 10mm screws with a J1 screwdriver on the bottom half of the innermost side panel of the device.
      • One side panel will not have an orange & white cable running through.
      询问修复机器人
      添加评论
    4. CASIO CDP-230R Key Replacement: 步骤 4 中的图像 1,3 CASIO CDP-230R Key Replacement: 步骤 4 中的图像 2,3 CASIO CDP-230R Key Replacement: 步骤 4 中的图像 3,3
      • Remove the innermost side panel by pinching the top and bottom of the panel and pulling the panel off with both hands.
      • Repeat steps one through four to remove the other side panel of the keyboard.
      添加评论
    5. CASIO CDP-230R Key Replacement: 步骤 5 中的图像 1,3 CASIO CDP-230R Key Replacement: 步骤 5 中的图像 2,3 CASIO CDP-230R Key Replacement: 步骤 5 中的图像 3,3
      • Remove the two black 30 mm J head screws with a J1 screwdriver to remove the long black bar.
      • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver and the two brackets from the back panel.
      • There will be two screws per bracket.
      询问修复机器人
      添加评论
    6. CASIO CDP-230R Key Replacement: 步骤 6 中的图像 1,3 CASIO CDP-230R Key Replacement: 步骤 6 中的图像 2,3 CASIO CDP-230R Key Replacement: 步骤 6 中的图像 3,3
      • Remove the eight silver 10mm x 1.5mm J head screws with a J1 screwdriver and the square tabs from the back panel.
      • Remove the eight silver 10mm J head screws with a J1 screwdriver underneath the square tabs.
      添加评论
    7. CASIO CDP-230R Key Replacement: 步骤 7 中的图像 1,3 CASIO CDP-230R Key Replacement: 步骤 7 中的图像 2,3 CASIO CDP-230R Key Replacement: 步骤 7 中的图像 3,3
      • Remove the 36 silver 10mm J head screws with a J1 screwdriver from the back panel.
      添加评论
    8. CASIO CDP-230R Key Replacement: 步骤 8 中的图像 1,3 CASIO CDP-230R Key Replacement: 步骤 8 中的图像 2,3 CASIO CDP-230R Key Replacement: 步骤 8 中的图像 3,3
      • Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
      • Having a extra pair of hands will be useful.
      • Grab the center of the front panel with two hands and lift to remove panel.
      • Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
      添加评论
    1. CASIO CDP-230R Key Replacement, Key: 步骤 9 中的图像 1,3 CASIO CDP-230R Key Replacement, Key: 步骤 9 中的图像 2,3 CASIO CDP-230R Key Replacement, Key: 步骤 9 中的图像 3,3
      • Locate the three screws behind the keys (left, center, and right).
      • Remove these 10mm J screws using a J1 screwdriver.
      • Grasp the white ribbon lined with foam and pull up to remove from the main circuit board.
      询问修复机器人
      添加评论
    2. CASIO CDP-230R Key Replacement: 步骤 10 中的图像 1,1
      • Place one hand on the side with fingers underneath the keys and one hand on the upper edge and lift off of the back panel.
      • Having an extra pair of hands will be useful.
      询问修复机器人
      添加评论
    3. CASIO CDP-230R Key Replacement: 步骤 11 中的图像 1,3 CASIO CDP-230R Key Replacement: 步骤 11 中的图像 2,3 CASIO CDP-230R Key Replacement: 步骤 11 中的图像 3,3
      • Pull up on the white key from the side nearest to you until the key lifts up.
      • Pull up on the two surrounding white keys before pulling up on the black key.
      询问修复机器人
      添加评论
    4. CASIO CDP-230R Key Replacement: 步骤 12 中的图像 1,3 CASIO CDP-230R Key Replacement: 步骤 12 中的图像 2,3 CASIO CDP-230R Key Replacement: 步骤 12 中的图像 3,3
      • Wiggle the white key from side to side and pull up to detach it from the rest of the board.
      询问修复机器人
      添加评论
    5. CASIO CDP-230R Key Replacement: 步骤 13 中的图像 1,3 CASIO CDP-230R Key Replacement: 步骤 13 中的图像 2,3 CASIO CDP-230R Key Replacement: 步骤 13 中的图像 3,3
      • To reattach the white key, snap the key back in place.
      • Flip the keyboard so the keys are laying on a flat surface.
      • Pull up on the black and white felt to dislodge the black shank.
      • Push up on the white key while pulling the felt up to reposition the black shank underneath the felt.
      添加评论
结论
To reassemble your device, follow step 13 and then the rest of the instructions in reverse order.
取消:我没有完成这个指南。
13等其他人完成本指南。
Areli Reyes
于10/01/17注册
545 声望
创作了4篇指南
团队
Cal Poly, Team S4-G2, Livingston Fall 2017 Cal Poly, Team S4-G2, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S4G2
4 名成员
创作了6篇指南
11指南评论
Thankyou very much - I have a CDP-200R that I had to pull apart - yours was the only post I could find that helped me decode what it took!
rooster0001 - 回复 分享
Me too, I have 200R need to replace the keys, but afraid to dismantle , now you save us all.thank you
Rus Azdy Ezzat Mohd Idrus - 回复 分享
Searched everywhere on how to fix my Casio CDP-220RBK and this was all I could find that actually helped! Awesome and very helpful guide!!!
albert einstien - 回复 分享
Thanks a lot. This manual is very detailed, and the only one I've found in the whole Internet.
Владимир Белявский - 回复 分享
Hello,
One of my kids lifted a black key from my piano. It won't come down fully and doesn't play when pressed. It's also harder to press, with more resistance.
Will I be able to put it back in place by following these instructions?
Many thanks.
Bernard Déry - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 124
总计 14,810
