跳转到主内容
加入维修社区 - 创建账户
Brother PT-1010 Keyboard Replacement
你所需要的
  1. Brother PT-1010 Keyboard Replacement, Remove Back Cover: 步骤 1 中的图像 1,1
    • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
    询问修复机器人
    添加评论
  2. Brother PT-1010 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove batteries, cassette tape, and cutter blade.
    询问修复机器人
    添加评论
  3. Brother PT-1010 Keyboard Replacement, Remove Screws: 步骤 3 中的图像 1,1
    • Use a phillips size #00 screwdriver to unscrew the 5 corner screws circled in the picture.
    询问修复机器人
    添加评论
  4. Brother PT-1010 Keyboard Replacement, Separate Device: 步骤 4 中的图像 1,1
    • Separate the top of the device from the bottom. Be very cautious when you separate the device, there is a ribbon attaching the top to the bottom.
    询问修复机器人
    添加评论
  5. Brother PT-1010 Keyboard Replacement, Remove side panels: 步骤 5 中的图像 1,1
    • Remove the two black side panels. They will easily fall out so just move them to the side until you are putting your device back together.
    询问修复机器人
    添加评论
  6. Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: 步骤 6 中的图像 1,3 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: 步骤 6 中的图像 2,3 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: 步骤 6 中的图像 3,3
    • Using your index finger and thumb, pull out the golden ribbon from the green circuit board.
    询问修复机器人
    添加评论
  7. Brother PT-1010 Keyboard Replacement, Remove Screws from Circuit Board: 步骤 7 中的图像 1,1
    • Use a phillips size #00 screwdriver to remove the two screws, circled in red, from the green circuit board.
    询问修复机器人
    添加评论
  8. Brother PT-1010 Keyboard Replacement, Remove Circuit Board: 步骤 8 中的图像 1,1
    • Carefully remove the green circuit board by pulling it straight up. Be careful not to break the LCD cable ribbon that connects the circuit board to the device.
    • The ribbon is very fragile so be careful to break it when pulling up on the circuit board.
    询问修复机器人
    添加评论
  9. Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: 步骤 9 中的图像 1,3 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: 步骤 9 中的图像 2,3 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: 步骤 9 中的图像 3,3
    • Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Haley Sweet
于10/30/14注册
460 声望
创作了4篇指南
团队
Baylor, Team 4-4, Williams Fall 2014 Baylor, Team 4-4, Williams Fall 2014 的会员
BU-WILLIAMS-F14S4G4
4 名成员
创作了4篇指南
3指南评论
Hi!
Thanks for this very helpful and detailed set of instructions. One small suggestion - assuming that replacing the keyboard means you need a working one to replace the old one with, you might want to consider adding “Parts: replacement keyboard” instead of “No parts required.”
Cheers,
Maria B
Maria Bitterli - 回复 分享
Please specify what is being replaced. Is the rubber keyboard the part that needs to be replaced?
Sincere Cavalier - 回复 分享
Screen is dull, what to do
Judy Baranczyk - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 30
总计 3,632
