跳转到主内容
加入维修社区 - 创建账户
Bottom Plate Removal
你所需要的
  1. Bottom Plate Removal, Remove back cover: 步骤 1 中的图像 1,1
    • Push down on the screw to depress the spring loaded hinge and release the door.
    询问修复机器人
    添加评论
  2. Bottom Plate Removal, Remove bottom cover: 步骤 2 中的图像 1,1
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
    询问修复机器人
    添加评论
  3. Bottom Plate Removal, Remove left front cover: 步骤 3 中的图像 1,1
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
    询问修复机器人
    添加评论
  4. Bottom Plate Removal, Remove front cover: 步骤 4 中的图像 1,2 Bottom Plate Removal, Remove front cover: 步骤 4 中的图像 2,2
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
    询问修复机器人
    添加评论
  5. Bottom Plate Removal, Remove right front cover: 步骤 5 中的图像 1,1
    • Remove two 3.9 mm #00 screws.
    询问修复机器人
    添加评论
  6. Bottom Plate Removal, Prepare bottom plate: 步骤 6 中的图像 1,2 Bottom Plate Removal, Prepare bottom plate: 步骤 6 中的图像 2,2
    • Remove two 3.4 mm #00 screws. Remove the plate holding the contacts in place.
    • Peel tape from the plate. Leave the tape attached to the flex circuit.
    • Remove the flex circuits from their retaining studs.
    询问修复机器人
    添加评论
  7. Bottom Plate Removal, Remove bottom plate: 步骤 7 中的图像 1,2 Bottom Plate Removal, Remove bottom plate: 步骤 7 中的图像 2,2
    • Remove one 3.3 mm #0 countersunk screw.
    • Remove one 3.9 mm #0 shoulder screw.
    • Remove four 3.3 mm #00 screws.
    • Pull a little slack through the housing on this flex cable.
    • Pop the plate off its posts, rotate slightly clockwise and pull gently through the loosened flex cable.
    • To the camera tech that left me a happy little note...I see you.
    询问修复机器人
    添加评论
  8. Bottom Plate Removal, Remove transport gears: 步骤 8 中的图像 1,2 Bottom Plate Removal, Remove transport gears: 步骤 8 中的图像 2,2
    • It's best to remove these parts now so they don't fall out later on in the repair.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Sam Gustafson
于09/01/22注册
14,384 声望
创作了78篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 43
总计 909
