跳转到主内容
加入维修社区 - 创建账户
Bose Soundlink Revolve Top Circuit Board Replacement
你所需要的
    1. Bose Soundlink Revolve Top Circuit Board Replacement, Bottom Circuit Board Access: 步骤 1 中的图像 1,2 Bose Soundlink Revolve Top Circuit Board Replacement, Bottom Circuit Board Access: 步骤 1 中的图像 2,2
      • Flip speaker over so that the bottom is facing up.
      • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
      询问修复机器人
      添加评论
    2. Bose Soundlink Revolve Top Circuit Board Replacement: 步骤 2 中的图像 1,3 Bose Soundlink Revolve Top Circuit Board Replacement: 步骤 2 中的图像 2,3 Bose Soundlink Revolve Top Circuit Board Replacement: 步骤 2 中的图像 3,3
      • Using the screwdriver, unscrew three screws.
      • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
      添加评论
    3. Bose Soundlink Revolve Top Circuit Board Replacement: 步骤 3 中的图像 1,2 Bose Soundlink Revolve Top Circuit Board Replacement: 步骤 3 中的图像 2,2
      • Remove the screw that is above the charging port.
      询问修复机器人
      添加评论
    4. Bose Soundlink Revolve Top Circuit Board Replacement: 步骤 4 中的图像 1,2 Bose Soundlink Revolve Top Circuit Board Replacement: 步骤 4 中的图像 2,2
      • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
      • Remove the bottom cover.
      询问修复机器人
      添加评论
    1. Bose Soundlink Revolve Top Circuit Board Replacement, Top Circuit Board: 步骤 5 中的图像 1,1
      • Using your hands, grip and separate the soft plastic and the metal casing away from each other with some small force.
      添加评论
    2. Bose Soundlink Revolve Top Circuit Board Replacement: 步骤 6 中的图像 1,1
      • Remove the (4) four screws shown around the top of the inside.
      • (2) two of the screws are shown here, the other side will look the same.
      询问修复机器人
      添加评论
    3. Bose Soundlink Revolve Top Circuit Board Replacement: 步骤 7 中的图像 1,2 Bose Soundlink Revolve Top Circuit Board Replacement: 步骤 7 中的图像 2,2
      • Pry up and remove the soft plastic casing from the rest of the device.
      询问修复机器人
      添加评论
    4. Bose Soundlink Revolve Top Circuit Board Replacement: 步骤 8 中的图像 1,2 Bose Soundlink Revolve Top Circuit Board Replacement: 步骤 8 中的图像 2,2
      • Remove the 3 screws holding down the top circuit board.
      询问修复机器人
      添加评论
    5. Bose Soundlink Revolve Top Circuit Board Replacement: 步骤 9 中的图像 1,1
      • Lift up and look on the underside of the circuit board.
      • Using the plastic opening tool, pry open the wide clamp keeping a ribbon to the top circuit board. The top circuit board can now freely be removed from the device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
13等其他人完成本指南。
Brian Butner
于09/27/17注册
927 声望
创作了3篇指南
团队
USF Tampa, Team S6-G2, Remmell Fall 2017 USF Tampa, Team S6-G2, Remmell Fall 2017 的会员
USFT-REMMELL-F17S6G2
4 名成员
创作了12篇指南
13指南评论
Hello,
I need to buy the TOP CIRCUIT BOARD … Where Can I buy it or could you sell me one ? Thank you my mail is skelet300@gmail.com
skelet300 - 回复 分享
I also need one of these boards and don’t really want to buy a complete used unit to repair mine, copydoc1@aol.com if you know of any resources, thanks in advance.
Jeff Pitt - 回复 分享
Same here. My speaker had one circuit replacement on warranty but now need a second replacement and I not willing to pay half the price of a new speaker each a every year. Can you help please ?
My e-mail is fmtbmp@gmail.com
fmpitschieller - 回复 分享
Hi, I need to buy the top and bottom circuit board and was wondering the same. Any help with where to purchase these would be appreciated,
Thanks, my email is fayclaybrook28@outlook.com
Fay Claybrook - 回复 分享
I am also looking for a top circuit board replacement. Where can I get one. michael@parsche.net
Michael Parsche - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 28
过去 30 天: 135
总计 15,884
