跳转到主内容
加入维修社区 - 创建账户
Bose Soundlink Flex Driver Replacement
你所需要的
    1. Bose Soundlink Flex Driver Replacement, Grille: 步骤 1 中的图像 1,1
      • Use a heat gun to warm up the device.
      • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
      询问修复机器人
      添加评论
    2. Bose Soundlink Flex Driver Replacement: 步骤 2 中的图像 1,1
      • Use an iFixit opening tool to pop off the eight clips on the grille.
      • Be patient and do not rush this process as you may otherwise damage the device.
      询问修复机器人
      添加评论
    3. Bose Soundlink Flex Driver Replacement: 步骤 3 中的图像 1,2 Bose Soundlink Flex Driver Replacement: 步骤 3 中的图像 2,2
      • Once the clips have been released, the only thing holding the grille on is glue.
      • Apply minimal force and the grille should pop right off the device.
      • Reheat the device to warm up the glue if there is difficulty in removing.
      询问修复机器人
      添加评论
    1. Bose Soundlink Flex Driver Replacement, Driver: 步骤 4 中的图像 1,3 Bose Soundlink Flex Driver Replacement, Driver: 步骤 4 中的图像 2,3 Bose Soundlink Flex Driver Replacement, Driver: 步骤 4 中的图像 3,3
      • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
      • Lift the driver out, being cautious of the wires still connected to the device.
      询问修复机器人
      添加评论
    2. Bose Soundlink Flex Driver Replacement: 步骤 5 中的图像 1,3 Bose Soundlink Flex Driver Replacement: 步骤 5 中的图像 2,3 Bose Soundlink Flex Driver Replacement: 步骤 5 中的图像 3,3
      • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
      • Pull the back panel off exposing the motherboard.
      询问修复机器人
      添加评论
    3. Bose Soundlink Flex Driver Replacement: 步骤 6 中的图像 1,2 Bose Soundlink Flex Driver Replacement: 步骤 6 中的图像 2,2
      • Desolder the joints that are connecting the speaker to the motherboard.
      • Solder the new speaker with the wire color in the same order.
      • Be cautious when removing and adding the solder to not damage the motherboard or burn yourself.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Kalvin Lee
于03/19/24注册
625 声望
创作了3篇指南
团队
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 UMass Dartmouth, Team 4-1, Shaddix Spring 2024 的会员
UMASSD-SHADDIX-S24S4G1
3 名成员
创作了41篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 29
过去 30 天: 101
总计 1,902
