跳转到主内容
加入维修社区 - 创建账户
Bose Soundlink Flex Battery Replacement
你所需要的
  1. Bose Soundlink Flex Battery Replacement, Grille: 步骤 1 中的图像 1,1
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
    询问修复机器人
    添加评论
  2. Bose Soundlink Flex Battery Replacement: 步骤 2 中的图像 1,1
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
    询问修复机器人
    添加评论
  3. Bose Soundlink Flex Battery Replacement: 步骤 3 中的图像 1,2 Bose Soundlink Flex Battery Replacement: 步骤 3 中的图像 2,2
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
    询问修复机器人
    添加评论
  4. Bose Soundlink Flex Battery Replacement, Battery: 步骤 4 中的图像 1,3 Bose Soundlink Flex Battery Replacement, Battery: 步骤 4 中的图像 2,3 Bose Soundlink Flex Battery Replacement, Battery: 步骤 4 中的图像 3,3
    • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
    • Lift the driver out, being cautious of the wires still connected to the device.
    询问修复机器人
    添加评论
  5. Bose Soundlink Flex Battery Replacement: 步骤 5 中的图像 1,3 Bose Soundlink Flex Battery Replacement: 步骤 5 中的图像 2,3 Bose Soundlink Flex Battery Replacement: 步骤 5 中的图像 3,3
    • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
    • Pull the back panel off exposing the motherboard.
    询问修复机器人
    添加评论
  6. Bose Soundlink Flex Battery Replacement: 步骤 6 中的图像 1,2 Bose Soundlink Flex Battery Replacement: 步骤 6 中的图像 2,2
    • Remove the three 1.7 mm screws from the motherboard using a TR6 Torx screwdriver.
    • Remove the single 1.4 mm screw from the motherboard using a TR5 Torx screwdriver.
    询问修复机器人
    添加评论
  7. Bose Soundlink Flex Battery Replacement: 步骤 7 中的图像 1,3 Bose Soundlink Flex Battery Replacement: 步骤 7 中的图像 2,3 Bose Soundlink Flex Battery Replacement: 步骤 7 中的图像 3,3
    • Take the motherboard out and take note of the battery attached.
    • Remove the insulation and the solder from the wiring.
    • Be careful not to damage the motherboard. Doing so will create a slew of problems for the speaker.
    • Solder the wires of the new battery onto the motherboard.
    • Be cautious when adding the solder to not damage the motherboard or burn yourself.
    添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
Kalvin Lee
于03/19/24注册
625 声望
创作了3篇指南
团队
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 UMass Dartmouth, Team 4-1, Shaddix Spring 2024 的会员
UMASSD-SHADDIX-S24S4G1
3 名成员
创作了15篇指南
1指南评论
How do I know which one is the positive and which one is the negative side of my battery connector in soundlink flex ? As I have already removed the old battery only.
SOM SATPATHY - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 18
过去 7 天: 95
过去 30 天: 475
总计 8,430
